Hi
I am getting a build failure on Geoserver, here is the error.
[INFO] ----------------------------------------------------------------------------
[INFO] Building GeoServer Web Application Module
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[WARNING]
Artifact javax.servlet:servlet-api:jar:2.4:provided retains local scope 'provided'
overriding broader scope 'compile'
given by a dependency. If this is not intended, modify or remove the local scope.
[INFO] [compiler:compile]
Compiling 71 source files to C:\projects\geoserver\1.4.x\web\target\classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
C:\projects\geoserver\1.4.x\web\src\main\java\org\geoserver\request\Dispatcher.java:[17,38
] package com.sun.corba.se.internal.core does not exist
[INFO] Total time: 1 minute 12 seconds
[INFO] Finished at: Tue May 30 10:30:46 CAT 2006
[INFO] Final Memory: 13M/38M
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM MSN : louiecw@anonymised.com
IM Skype: louicw
