Hi Justin,
I am getting a build failure on the Geoserver project in the WMS module?
[INFO] Deleting directory C:\projects\geoserver\1.4.x\wms\target
[INFO] Deleting directory C:\projects\geoserver\1.4.x\wms\target\classes
[INFO] Deleting directory C:\projects\geoserver\1.4.x\wms\target\test-classes
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[WARNING] While downloading itext:itext:1.3
This artifact has been relocated to com.lowagie:itext:1.3.
[INFO] [compiler:compile]
Compiling 81 source files to C:\projects\geoserver\1.4.x\wms\target\classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
C:\projects\geoserver\1.4.x\wms\src\main\java\org\vfny\geoserver\wms\responses\map\kml\KML
Writer.java:[23,28] package javax.media.jai.util does not exist
Writer.java:[414,44] cannot resolve symbol
symbol : class Range
location: class org.vfny.geoserver.wms.responses.map.kml.KMLWriter
[INFO] Total time: 30 seconds
[INFO] Finished at: Tue May 30 17:22:16 CAT 2006
[INFO] Final Memory: 10M/23M
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM MSN : louiecw@anonymised.com
IM Skype: louicw
I had installed a Java 1.4 so I need to install the JAI stuff, the build succeeded afterwards..
Thanks
Clint Lewis wrote:
Hi Justin,
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM Skype: louicw
