Any one know why I'm getting this error? I just built the latest Geotools 2.2.x jars.
[INFO] ----------------------------------------------------------------------------
[INFO] Building Web Map Service Module
[INFO] task-segment: [clean, install, javadoc:javadoc]
[INFO] [clean:clean]
[INFO] Deleting directory /Users/Jesse/Development/repo/geoserver/trunk/wms/target
[INFO] Deleting directory /Users/Jesse/Development/repo/geoserver/trunk/wms/target/classes
[INFO] Deleting directory /Users/Jesse/Development/repo/geoserver/trunk/wms/target/test-classes
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[WARNING] While downloading itext:itext:1.3
This artifact has been relocated to com.lowagie:itext:1.3.
[INFO] [compiler:compile]
Compiling 88 source files to /Users/Jesse/Development/repo/geoserver/trunk/wms/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/Users/Jesse/Development/repo/geoserver/trunk/wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMLWriter.java:[161,19] cannot find symbol
symbol : method setNumDecimals(int)
location: class org.geotools.gml.producer.GeometryTransformer
Currently geoserver builds against 2.2.0, so possibly a change was made
on 2.2.x that breaks things? I also remember this error a while back, do
you have a fresh checkout of geoserver? Also, are you building geoserver
trunk?
[INFO]
[INFO]
trunk/wms/target
[INFO]
[INFO]
find symbol
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
!DSPAM:1004,452e83f9310612207481331!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Ok just had to clean out my repository 2.2.0 geotools jars. Seems something old got in there.
Jesse
[INFO]
[INFO]
trunk/wms/target
[INFO]
[INFO]
find symbol
