I am a newbie to Geoserver.
Got the code downloaded via svn. Trying to build it using maven. Keep
getting the same "Fatal error"
when trying mvn install. Even dowloaded a different version of maven, and
different jdk versions..
Need help. Thanks!
[INFO]
[ERROR] FATAL ERROR
[INFO]
[INFO]
org.apache.maven.tools.plugin.scanner.MojoScanner.setActiveExtractors(Ljava/util/Set;)V
[INFO]
[INFO] Trace
java.lang.NoSuchMethodError:
at
org.apache.maven.plugin.plugin.AbstractGeneratorMojo.execute(AbstractGeneratorMojo.java:116)
at
org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:451)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:558)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:499)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:478)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:330)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:291)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:142)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:336)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at
org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at
org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
[INFO]
[INFO] Total time: 8 seconds
[INFO] Finished at: Fri Apr 25 15:41:12 EDT 2008
[INFO] Final Memory: 15M/82M
[INFO]
View this message in context: http://www.nabble.com/Build-failure-tp16905158p16905158.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
