[Geoserver-devel] Build failures on ares
it seems the spurious build failure rate on Ares is going up.
I cannot really get why this is happening, but some could be related to the extensive usage of file.deleteOnExit
in some of the failing test, in particular, the CoverageStoreTest in REST config, which is
particularly fail happy uses that a lot.
I was thinking of adding a service in GeoServerTestSupport to register files to be removed
at the end of the test, instead of relying on the VM exit.
Another thing that could be attempted would be to extend to all build environments the
code that under windows only tries to delete a directory mutliple times. On Linux in the local
FS that should be unecessary, but I guess Ares is using NFS to store the workspaces,
and that might result in issues similar to windows.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
