I’ve been having test failures locally on geoserver trunk for some time, but since I am not all that active there and no one else seems to be complaining I didn’t bring it up on the list. Today I finally found some time to investigate, and actually found two issues. Now I get all tests passing
xerces version conflict - For most modules in GeoServer is identifying xercesImpl 2.6.2 as the correct one to include on the classpath, however for org.geoserver:main it is using 2.4.0. This is causing AbstractMethodError’s at runtime, as you might expect. I tried bumping the version in geoserver’s main pom to 2.6.2 and tests pass, any objections to committing it?
networking in coverage setup - this one is a little weird… redhat based systems like my fedora laptop have a weird glitch where setting a custom hostname during the install process doesn’t necessarily update the /etc/hosts file, then some programs have issues when “myname.localdomain” doesn’t resolve. The JVM seems to be one of those programs. Ok, so I fixed my hosts file. The weird part is that I was running into those errors during setup of coveragestores in mock data directories for GeoServer’s unit tests, should there be networking going on during this operation? I’m attaching a stack trace for one of the failing tests to this mail.
Thanks David; I was just stressing over the xerces version conflict (trying to test geotools patches against geoserver). Please commit
It is hard to cut down on networking going on during units tests; some classes like URL like to hit the network for hashcode and equals etc…
Jody Garnett
On Sunday, 19 June 2011 at 12:50 PM, David Winslow wrote:
EditLive Enterprise is the world’s most technically advanced content
authoring tool. Experience the power of Track Changes, Inline Image
Editing and ensure content is compliant with Accessibility Checking. http://p.sf.net/sfu/ephox-dev2dev
Looking into the xerces version hell for a bit; the root pom explicitly has 2.4.0 in the dependency management section.
GeoTools meanwhile has 2.7.1 - so my guess is most of the modules get xerces as a transitive dependency; and main that actually uses it directly is the odd fish out.
So this appears to be a long standing issue? Any idea why it is hitting us today…
Jody Garnett
Jody Garnett
After you hint to use xerces 2.7.1 most of geoserver builds for me; I have one failure in the flow control extension:
Test set: org.geoserver.flow.controller.UserFlowControllerTest
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.226 sec <<< FAILURE!
testConcurrentRequestsSingleUser(org.geoserver.flow.controller.UserFlowControllerTest) Time elapsed: 1.212 sec <<< FAILURE!
junit.framework.AssertionFailedError: expected: but was:
at junit.framework.Assert.fail(Assert.java:47)
at junit.framework.Assert.failNotEquals(Assert.java:280)
at junit.framework.Assert.assertEquals(Assert.java:64)
at junit.framework.Assert.assertEquals(Assert.java:71)
at org.geoserver.flow.controller.UserFlowControllerTest.testConcurrentRequestsSingleUser(UserFlowControllerTest.java:49)
Jody Garnett
Jody Garnett
Jody Garnett
On Sun, Jun 19, 2011 at 8:05 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
<<< FAILURE!
junit.framework.AssertionFailedError: expected:<PROCESSING> but
was:<STARTED>
at
Yeah, these random exception occur every now and then on other
systems... but not on my machines and very rarely on the build box...
As for Xerces, I believe you are both building with java 6 already?
I found that removing the dependency solid (from the main pom) made
the build work fine, too
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
Yes, I saw this behavior on oracle jvm 1.6.0_26 and whichever openjdk
release is current in fedora (I'm not currently at my computer.) I
haven't tried with a java 5 setup since I started having trouble on
this machine.
<<< FAILURE!
was:<STARTED>
at
Ing. Andrea Aime
Tech lead
this machine.
<<< FAILURE!
was:<STARTED>
at
Ing. Andrea Aime
Tech lead
this machine.
<<< FAILURE!
was:<STARTED>
at
Ing. Andrea Aime
Tech lead
Jody, here is the bug report I filed for this issue:
GEOS-4462: Intermittent control-flow {User,Global}FlowControllerTest failures break build http://jira.codehaus.org/browse/GEOS-4462
On 19/06/11 14:57, Andrea Aime wrote:
On Sun, Jun 19, 2011 at 8:05 AM, Jody Garnett<jody.garnett@anonymised.com> wrote:
<<< FAILURE!
Time elapsed: 1.212 sec<<< FAILURE!
was:<STARTED>
at
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Ing. Andrea Aime
Tech lead
