[Geoserver-devel] Build from trunk failing
I'm trying to build GeoServer for the first time but can't get a
successful build.
I've followed the steps in the developers guide and after installing
all the tools and getting the source code from trunk and trying "mvn
clean install", the build fails.
Is this happening to anyone else?
Here's the build report:
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [54.693s]
[INFO] Core Platform Module .............................. SUCCESS [9.181s]
[INFO] Open Web Service Module ........................... SUCCESS [12.438s]
[INFO] Main Module ....................................... SUCCESS [4:11.383s]
[INFO] Web Feature Service Module ........................ FAILURE [5:18.598s]
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:47.477s
[INFO] Finished at: Mon Jul 02 17:01:42 BST 2012
[INFO] Final Memory: 16M/45M
[ERROR] Failed to execute goal
org.apache.maven.plugins:maven-surefire-plugin:2.10:test
(default-test) on project w
fs: There are test failures.
[ERROR]
[ERROR] Please refer to
D:\Projects\GeoServer\geoserver-trunk\src\wfs\target\surefire-reports
for the individual te
st results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to
execute goal org.apache.maven.plugins:maven-suref
ire-plugin:2.10:test (default-test) on project wfs: There are test failures.
Please refer to
for the individual test resul
ts.
        at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:213)
        at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
        at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
        at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
        at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
        at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
        at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
        at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
        at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
        at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
        at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
        at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
        at java.lang.reflect.Method.invoke(Method.java:601)
        at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
        at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
        at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
        at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: org.apache.maven.plugin.MojoFailureException: There are
test failures.
Please refer to
ts.
        at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:87)
        at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:641)
        at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:615)
        at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireM
ojo.java:137)
        at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:98)
        at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
        at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
        ... 19 more
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions,
please read the following articles:
[ERROR] [Help 1]
http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
João
Hi João,
It seems like there was a test failure in the main module. The failed test should have showed up in your build output before the reactor summary, can you provide the output? Thanks.
-Justin
On Mon, Jul 2, 2012 at 10:09 AM, João Duarte <jdduarte@anonymised.com> wrote:
I’m trying to build GeoServer for the first time but can’t get a
successful build.
I’ve followed the steps in the developers guide and after installing
all the tools and getting the source code from trunk and trying “mvn
clean install”, the build fails.
Here’s the build report:
[INFO]
[INFO] GeoServer … SUCCESS [54.693s]
[INFO] Core Platform Module … SUCCESS [9.181s]
[INFO] Open Web Service Module … SUCCESS [12.438s]
[INFO] Main Module … SUCCESS [4:11.383s]
[INFO] Web Feature Service Module … FAILURE [5:18.598s]
[INFO] Web Coverage Service Module … SKIPPED
[INFO] Web Map Service Module … SKIPPED
[INFO] GeoServer Web Modules … SKIPPED
[INFO] Core UI Module … SKIPPED
[INFO] Security UI Module … SKIPPED
[INFO] GeoServer Security Modules … SKIPPED
[INFO] GeoServer CAS Security Module … SKIPPED
[INFO] GeoServer JDBC Security Module … SKIPPED
[INFO] GeoServer LDAP Security Module … SKIPPED
[INFO] Web Coverage Service 1.0 Module … SKIPPED
[INFO] Web Coverage Service 1.1 Module … SKIPPED
[INFO] GeoWebCache (GWC) Module … SKIPPED
[INFO] REST Support Module … SKIPPED
[INFO] REST Configuration Service Module … SKIPPED
[INFO] WMS UI Module … SKIPPED
[INFO] GWC UI Module … SKIPPED
[INFO] WFS UI Module … SKIPPED
[INFO] Demoes Module … SKIPPED
[INFO] WCS UI Module … SKIPPED
[INFO] GeoServer Web Application … SKIPPED
[INFO] Community Space … SKIPPED
[INFO] GeoServer Extensions … SKIPPED
[ERROR]
st results.
[ERROR] → [Help 1]
Please refer to
ts.
test failures.
Please refer to
ts.
ojo.java:137)
… 19 more
[ERROR]
[ERROR]
[ERROR] [Help 1]
[ERROR]
João
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
Thanks for the reply.
Here's the output of the failed test:
Results :
Failed tests:
testIsModified(org.geoserver.security.xml.XMLUserGroupServiceTest)
  testEmptyPassword(org.geoserver.security.xml.XMLUserGroupServiceTest):
expected:<0> but was:<6>
Tests in error:
  testEraseCredentials(org.geoserver.security.xml.XMLUserGroupServiceTest):
Already locked
  testPasswordRecoding(org.geoserver.security.xml.XMLUserGroupServiceTest):
Already locked
  testGlobal(org.geoserver.template.GeoServerTemplateLoader2Test):
org.geoserver.data.test.LiveData cannot be cast
to org.geoserver.data.test.MockData
Tests run: 460, Failures: 2, Errors: 3, Skipped: 0
On Mon, Jul 2, 2012 at 6:10 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi João,
-Justin
successful build.
[INFO]
[INFO]
[54.693s]
[9.181s]
[12.438s]
[4:11.383s]
[5:18.598s]
[INFO]
[INFO]
[INFO]
[ERROR]
st results.
[ERROR] -> [Help 1]
failures.
Please refer to
ts.
at
at
at
at
at
at
at
at
at
at
at
at
at
test failures.
Please refer to
ts.
at
at
at
at
ojo.java:137)
at
at
at
... 19 more
[ERROR]
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
João
Exclusive live event will cover all the ways today's security and
Justin Deoliveira
João
Thanks João,
Looks like a legit failure. Unfortunately non of the main devs use windows for building and our continuous build server uses linux so i imagine it is a windows specific thing we have just missed, which is pretty common.
Can you open a jira report with all the relevant info and one us will try to look into this when we get a chance. Or if you are up for trying to patch the tests to pass that would be even better.
Thanks.
-Justin
On Mon, Jul 2, 2012 at 11:26 AM, João Duarte <jdduarte@anonymised.com> wrote:
Hi Justin,
Here’s the output of the failed test:
Results :
Failed tests:
Tests in error:
Already locked
Already locked
Hi João,
-Justin
successful build.
[INFO]
[INFO]
[54.693s]
[9.181s]
[12.438s]
[4:11.383s]
[5:18.598s]
[INFO]
[INFO]
[INFO]
[ERROR]
st results.
[ERROR] → [Help 1]
failures.
Please refer to
ts.
at
at
at
at
at
at
at
at
at
at
at
at
at
test failures.
Please refer to
ts.
at
at
at
at
ojo.java:137)
at
at
at
… 19 more
[ERROR]
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
João
Justin Deoliveira
João
Justin Deoliveira
Thanks for the reply Justin.
I've opened a Jira report (sorry if it misses something):
http://jira.codehaus.org/browse/GEOS-5203
In the meanwhile I'll also try to solve the issue myself.
Joao
On Mon, Jul 2, 2012 at 8:29 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Thanks João,
Thanks.
-Justin
Hi Justin,
Results :
Failed tests:
Tests in error:
Already locked
Already locked
wrote:
> Hi João,
> test
> can
> -Justin
>> Hi all,
>> successful build.
>> [INFO]
>> [INFO]
>> [54.693s]
>> [9.181s]
>> [12.438s]
>> [4:11.383s]
>> [5:18.598s]
>> [INFO]
>> [INFO]
>> [INFO]
>> [ERROR]
>> st results.
>> [ERROR] -> [Help 1]
>> failures.
>> Please refer to
>> ts.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> test failures.
>> Please refer to
>> ts.
>> at
>> at
>> at
>> at
>> ojo.java:137)
>> at
>> at
>> at
>> ... 19 more
>> [ERROR]
>> [ERROR]
>> [ERROR] [Help 1]
>> [ERROR]
>> the
>> command
>> João
>> Discussions
>> malware
>> _______________________________________________
>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
> Justin Deoliveira
João
Justin Deoliveira
João
