[Geoserver-devel] build.geoserver.org - apollo-slave-02 removal
Hello All,
Just as a heads up, the apollo-slave-02 is being decommissioned shortly. All capabilities of that server will be moved to apollo-slave-01.
I’ve moved over PostGIS and the cite test configuration, and those appear to be working, although there appear to have been some failures in other tests caused by this.
Right now:
  • There is an OGR failure in geoserver-2.15 / geoserver-master. I am investigating.
  • The geoserver-master-app-schema-online is has a small number of PostGIS failures. These seem like they may be legitimate.
    Torben
