[Geoserver-devel] build.geoserver.org - HTTPS is now enabled
HTTPS has been enabled on build.geoserver.org (and HTTP has been disabled).
Torben
I’ve also reverted the downloads site to use https again, so links should be working.
Torben
On Tue, Jun 4, 2019 at 11:30 AM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Thank you Torben that is great news.
Jody Garnett
Thanks.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Tue, Jun 4, 2019 at 9:09 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Tue, 4 Jun 2019 at 11:40, Torben Barsballe via Geoserver-devel <geoserver-devel@lists.sourceforge.net> wrote:
I've also reverted the downloads site to use https again, so links should be working.
Torben
Torben
Geoserver-devel mailing list
Woot!
Il mar 4 giu 2019, 20:31 Torben Barsballe via Geoserver-devel <geoserver-devel@lists.sourceforge.net> ha scritto:
Torben
Awesome thanks!
Jason Newmoyer
Newmoyer Geospatial Solutions
843.606.0424
jason@anonymised.com
