[Geoserver-devel] build.geoserver.org setup for un-reliable builds?
while starting to perform the release I looked at build.geoserver.org and found a nightly
build with a suspicious, classpath related failure (something like “org.geoserver.platform
package not found”, which should never happen).
Looking around I see there are no concurrent build group limitations on build.geoserver.org
like it’s done in Ares, meaning that a geotools/geoserver build can be rebuild and replaced
while a nightly, release or other dependent build runs, making it fail like above.
I’m going to use Ares for the build, and in the meantime, I’m asking: was that an oversight?
I don’t think build.geoserver.org can work setup as it is now.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
build.geoserver.org is using a newer version of Jenkins that ares, and as such has some different solutions to some of these issues. In this case, it is using the Locks and Latches plugin to control what can and cannot be executed concurrently. Right now, there are two different locks set up - “GeoServer” and “Docs”.
So, I think it should be working as-is? However, the fact that you are seeing a failure like that is concerning.
Nick - you set up the locks and latches, was there a specific reason why build.geoserver.org is not using the same concurrent execution group setup as ares? Is it just because of the version of Jenkins?
Torben
On Mon, Jul 31, 2017 at 1:21 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
On Mon, Jul 31, 2017 at 6:26 PM, Torben Barsballe <
tbarsballe@anonymised.com> wrote:
Hi Andrea,
"GeoServer" and "Docs".
Right, it seems that the current concurrent build solution is at least not
fully configured, e.g., a geoserver nightly build should
not be allowed to run while a geoserver one is running (and vice versa).
And same goes for geotools of course, the
group should be one large all encompassing gt/gs/gwc, since upstream
projects might wipe jars off the downstream
builds and make them fail otherwise.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Torben,
Yes, the new version of Jenkins doesn’t have the same settings as the Ares did. The capability of blocking concurrent builds isn’t something native to Jenkins now, it’s managed from the plugin.
Nick
On Mon, Jul 31, 2017 at 12:26 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hi Andrea,
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel@anonymised.comrge.net
Nick Stires
DevOps Engineer | Boundless
nstires@anonymised.com9…
Mobile: +1 561-713-0922
