geoserver-2.19.x-java11 last passed on August 16th
The build failures here … are all different. Did anyone change the jenkins configuration on the 16th?
https://build.geoserver.org/view/geoserver/job/geoserver-2.19.x-java11/95/
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-main: Compilation failure: Compilation failure:
[ERROR] /var/lib/jenkins/workspace/java11c/src/main/src/main/java/org/geoserver/catalog/ResourcePool.java:[1881,32] reference to WebMapTileServer is ambiguous
[ERROR] both constructor WebMapTileServer(java.net.URL,org.geotools.http.HTTPClient,java.util.Map<java.lang.String,java.lang.String>) in org.geotools.ows.wmts.WebMapTileServer and constructor WebMapTileServer(java.net.URL,org.geotools.http.HTTPClient,org.geotools.ows.wmts.model.WMTSCapabilities) in org.geotools.ows.wmts.WebMapTileServer match
https://build.geoserver.org/view/geoserver/job/geoserver-2.19.x-java11/100/console
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-wps-cluster-hazelcast: Execution default of goal com.coveo:fmt-maven-plugin:2.4.0:check failed. ArrayIndexOutOfBoundsException: Index 1 out of bounds for length 0 → [Help 1]
https://build.geoserver.org/view/geoserver/job/geoserver-2.19.x-java11/101/console
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-control-flow: There are test failures.
https://build.geoserver.org/view/geoserver/job/geoserver-2.19.x-java11/102/consoleFull
[ERROR] /var/lib/jenkins/workspace/java11c/src/wfs/src/main/java/org/geoserver/wfs/xml/v1_1_0/FeatureCollectionTypeBinding.java:[235,73] incompatible types: java.lang.Object cannot be converted to org.geotools.feature.FeatureCollection
https://build.geoserver.org/view/geoserver/job/geoserver-2.19.x-java11/103/consoleFull
[ERROR] /var/lib/jenkins/workspace/java11c/src/web/gwc/src/main/java/org/geoserver/gwc/web/layer/GeoServerTileLayerEditor.java:[52,30] package org.geoserver.platform does not exist
https://build.geoserver.org/view/geoserver/job/geoserver-2.19.x-java11/104/consoleFull
Jody Garnett
