[Geoserver-devel] Build keeps on failing on Travis-CI for Oracle JDK, on unsigned jar entries
the Travis build keeps on failing in the security UI LDAP module with this error:
Tests run: 5, Failures: 0, Errors: 1, Skipped: 4, Time elapsed: 43.477 sec <<< FAILURE!
testTestConnectionWitUserGroupService(org.geoserver.web.security.ldap.LDAPAuthProviderPanelTest)  Time elapsed: 39229 sec  <<< ERROR!
org.jasypt.exceptions.EncryptionInitializationException: java.lang.SecurityException: JCE cannot authenticate the provider BC
	at org.jasypt.encryption.pbe.StandardPBEByteEncryptor.initialize(StandardPBEByteEncryptor.java:708)
	at org.jasypt.encryption.pbe.StandardPBEByteEncryptor.encrypt(StandardPBEByteEncryptor.java:830)
	at org.geoserver.web.GeoserverWicketEncrypterFactory$CryptImpl.crypt(GeoserverWicketEncrypterFactory.java:74)
	at org.apache.wicket.util.crypt.AbstractCrypt.encryptStringToByteArray(AbstractCrypt.java:163)
	at org.apache.wicket.util.crypt.AbstractCrypt.encryptUrlSafe(AbstractCrypt.java:86)
	at org.apache.wicket.protocol.http.request.CryptedUrlWebRequestCodingStrategy.encodeURL(CryptedUrlWebRequestCodingStrategy.java:229)
	at org.apache.wicket.protocol.http.request.CryptedUrlWebRequestCodingStrategy.encode(CryptedUrlWebRequestCodingStrategy.java:140)
	at org.geoserver.web.GeoServerRequestEncodingStrategy.encode(GeoServerRequestEncodingStrategy.java:103)
	at org.apache.wicket.RequestCycle.encodeUrlFor(RequestCycle.java:811)
	at org.apache.wicket.RequestCycle.urlFor(RequestCycle.java:1011)
	at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:491)
	at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:413)
	at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:302)
	at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:243)
	at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:288)
	at org.geoserver.web.security.ldap.LDAPAuthProviderPanelTest.setupPanel(LDAPAuthProviderPanelTest.java:87)
	at org.geoserver.web.security.ldap.LDAPAuthProviderPanelTest.setupPanel(LDAPAuthProviderPanelTest.java:73)
	at org.geoserver.web.security.ldap.LDAPAuthProviderPanelTest.testTestConnectionWitUserGroupService(LDAPAuthProviderPanelTest.java:117)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.lang.reflect.Method.invoke(Method.java:483)
	at org.apache.maven.surefire.booter.ForkedBooter.runSuitesInProcess(ForkedBoo-ter.java:115)
Caused by: java.lang.SecurityException: JCE cannot authenticate the provider BC
	at javax.crypto.JceSecurity.getInstance(JceSecurity.java:114)
	at javax.crypto.SecretKeyFactory.getInstance(SecretKeyFactory.java:244)
	at org.jasypt.encryption.pbe.StandardPBEByteEncryptor.initialize(StandardPBEByteEncryptor.java:667)
	... 51 more
Caused by: java.util.jar.JarException: file:/home/travis/.m2/repository/org/apache/directory/server/apacheds-all/1.5.5/apacheds-all-1.5.5.jar has unsigned entries - org/apache/directory/server/configuration/ApacheDS$1.class
	at javax.crypto.JarVerifier.verifySingleJar(JarVerifier.java:464)
	at javax.crypto.JarVerifier.verifyJars(JarVerifier.java:322)
	at javax.crypto.JarVerifier.verify(JarVerifier.java:250)
	at javax.crypto.JceSecurity.verifyProviderJar(JceSecurity.java:160)
	at javax.crypto.JceSecurity.getVerificationResult(JceSecurity.java:186)
	at javax.crypto.JceSecurity.getInstance(JceSecurity.java:110)
	... 53 more
It’s affecting both the Oracle JDK7 and JDK8 builds, but not the openjdk one:
https://travis-ci.org/geoserver/geoserver/jobs/55093376
I cannot reproduce using Oracle JDK 7 or JDK 8 on Windows, any clue as to why that might be happening?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Oracle won’t let you load security providers in their JDK/JRE unless the jar is signed (with a trust chain configured for the JVM session). OpenJDK doesn’t restrict this.
It looks like apacheds-all-1.5.5.jar is repackaging the bouncy castle security provider in there, and this is breaking existing signatures.
The kind of looks like an upstream apacheds issue - but caveated, that’s just based on a quick glance at the stacktrace.
On Fri, Mar 20, 2015 at 7:47 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
	... 51 more
	... 53 more
Ing. Andrea Aime
@geowolf
Technical Lead
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
On Sat, Mar 21, 2015 at 12:58 AM, Chris Bennight <chris@anonymised.com> wrote:
Oracle won't let you load security providers in their JDK/JRE unless the
doesn't restrict this.
Ok, we'll look into it but... why isn't the same happening on my windows
box, with Oracle JDK 7 and Oracle JDK 8?
Is the windows JDK subject to different rules than a Linux one?
Anyways, I can confirm apacheds-all does contain a repackaging of
bouncycastle providers, from my local repo, looking
in the jar with 7z, it's there:
C:\Users\aaime\.m2\repository\org\apache\directory\server\apacheds-all\1.5.5\apacheds-all-1.5.5.jar\org\bouncycastle\
By the name it sort of seems there is also a non "all" version available,
I'll see if we can depend on smaller jars which
hopefully do not repackage bouncycastle
Ing. Andrea Aime
@geowolf
Technical Lead
If the regular bouncycastle jar is included as well there will be classloader race - if the unbundled bouncycastle gets on the classloader first you will be fine; might be something different with the sort/load order on windows?
You can “install” in in the jre/lib directory (similar to how the jai native stuff installs, but under security) - but that’s probably not a good solution.
If the UI LDAP module is getting packaged then either maven-shade or maven-dependency plugin can be used to strip/extract the classes. Just add the bouncycastle jar as a non-packaged file.
Alternatively if it can be ensured that it loads on the classpath before the apacheds-all then it will “just work”.
I’d be happy to take a look at it tomorrow if it’s not already fixed :slight_smile:
Chris
On Fri, Mar 20, 2015 at 8:04 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ok, we’ll look into it but… why isn’t the same happening on my windows box, with Oracle JDK 7 and Oracle JDK 8?
Anyways, I can confirm apacheds-all does contain a repackaging of bouncycastle providers, from my local repo, looking
in the jar with 7z, it’s there:
C:\Users\aaime.m2\repository\org\apache\directory\server\apacheds-all\1.5.5\apacheds-all-1.5.5.jar\org\bouncycastle\
By the name it sort of seems there is also a non “all” version available, I’ll see if we can depend on smaller jars which
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, Mar 21, 2015 at 1:12 AM, Chris Bennight <chris@anonymised.com> wrote:
order on windows?
You can "install" in in the jre/lib directory (similar to how the jai
native stuff installs, but under security) - but that's probably not a good
solution.
the apacheds-all then it will "just work".
I'd be happy to take a look at it tomorrow if it's not already fixed :slight_smile:
That would be much appreciated, I'm about to hop on a plane and I'll be
travelling all day tomorrow and Sunday too.
By the looks of it, we need apacheds-all. The strange thing is that
apparently maven uses pom.xml order to
order classpath entries and gs-main, from which we inherit bouncycastle, is
declared before the spring-ldap-test
from which we get apacheds-all ... but wait, aren't test dependecies loaded
before the normal one in test runs?
If so, then maybe declaring a bouncycastle dependency before the
spring-ldap-test one will do the trick
Ing. Andrea Aime
@geowolf
Technical Lead
Since Maven 2.0.9 (IIRC), dependencies are on the classpath in pom order, with all inherited dependencies afterwards. gs-main:test is a dependency of the parent pom, so spring-ldap-test and its apacheds-all dependency won the race.
The other change required for success was to change the Travis CI build from "clean test" to "clean install" to make sure changes can be resolved across modules. Otherwise, we are testing changed modules but not integration between them; this was resulting in much Travis CI breakage. According to the docs, pull requests do not result in repository cache update.
Done and merged:
https://github.com/geoserver/geoserver/pull/1001
Andrea, your bouncycastle security provider dependency order fix worked, but there is still an (apparently) unrelated failure for Oracle JDK 7 in wps-core ExecuteTest. Intermittent problem? Another victim of -T2?
I have made another test pull request to see if we get the same result.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz>
New Zealand
On Fri, Apr 3, 2015 at 4:44 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Done and merged:
Thank you!
Can you please elaborate what makes you think T2 is the cause?
And which were the other victims of -T2?
I normally build with -T4 (GeoServer) or -T8 (GeoTools) and haven't
experienced random failures
Ing. Andrea Aime
@geowolf
Technical Lead
No evidence. Just suspicion. I have had a local builds fail intermittently with -T2 so now avoid using it.
Kind regards,
Director
New Zealand
Test pull requests with five commits each show no difference in Travis CI reliability with and without -T2.
With -T2:
https://github.com/geoserver/geoserver/pull/1002
Without -T2:
https://github.com/geoserver/geoserver/pull/1003
Andrea, I see you have already committed fixes for the wps-core ProcessMonkey and CRS failures. Thanks!
I will make another pull request to see if Travis CI reliability improves.
Kind regards,
Director
New Zealand
Andrea, here is a pull request with ten commits, drip fed to trigger Travis CI for each, to test whether your most recent fixes improve build stability:
https://github.com/geoserver/geoserver/pull/1004
Kind regards,
Director
New Zealand
On Sat, Apr 4, 2015 at 11:16 PM, Ben Caradoc-Davies <ben@anonymised.com>
Right... I still saw a failure in CSW, I don't have a link to it, but it
seemed a validation failure,
I'm guessing code trying to fetch schemas to perform validation and failing
to do so
Ing. Andrea Aime
@geowolf
Technical Lead
to do so
This one fails in gs-main:
https://s3.amazonaws.com/archive.travis-ci.org/jobs/57193585/log.txt
All the failures in this build appear to be CRS-lookup-related. Is there a potential race condition initialising the EPSG database when two modules attempt to do so concurrently?
Kind regards,
Director
New Zealand
to do so
Other than this single failed build, we now have 29 out of 30 Travis CI builds passing for the 10 commits in PR #1004. Pretty close to announcing that Travis CI for GeoServer is back in business!
Kind regards,
Director
New Zealand
On Sun, Apr 5, 2015 at 1:21 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
failing
to do so
There is potential for pretty much anything in the universe, but
the ThreadedHsqlEpsgFactory uses NIO locks
to prevent two processes to try and unpack the hsql database at the same
time, so in theory we should have issues
(well aware that practice does not always agree).
Also, we don't have any initialization error from the hsql subsystem, which
is odd too.
But yeah, from the error it kind of looks as if the EPSG database was not
even available.
Also, the failure happens in the main module, the modules built in parallel
are parent
poms and other modules that are just dependencies sets, so I don't see
anything
else that could have tried to initialize the EPSG database in parallel
Long story short, I don't have anything to work against at the moment...
Ing. Andrea Aime
@geowolf
Technical Lead
