I’m looking into adding this (http://jira.codehaus.org/browse/GEOT-4597) feature to the geotools/geoserver.
The intention is to add to geotools the capability to create an ImageMosaicReader using hints without the need to add or modify properties files somewhere.
The idea is:
Starting from an existing schema (or Datastore), we can navigate into its structure (validating granules) to create an imagemosaic CatalogGranule.
Essentially no accessory files are needed (*.properties) but still some configuration (those located into the datastore.properties) should be passed via Hints I believe.
The Hints.MOSAIC_LOCATION_ATTRIBUTE is still needed and will be used to store generated accessory files such as the Imagemosaic.properties file and the sample_image and is also considered the default parent dir of relative paths for granules.
The entry point will be the ImageMosaicReader constructor:
// Check source
if (source instanceof ImageMosaicDescriptor) {
initReaderFromDescriptor((ImageMosaicDescriptor) source, uHints);
} else if (checkForDatastore(uHints)){
// if Hints contains all the needed params to configure a Mosaic (datastore connection, etc)
initReaderFromDescriptor(createGranuleDescriptorFromHints(uHints), uHints);
} else {
// normal filesystem scan
initReaderFromURL(source, localHints);
Essentially the condition to distinguish from the classic folder based scan and the new DataStore based scan is in the content of Hints.
If we can locate all the needed information to start the navigation we assume to use the DataStore scan mode (which essentially reads from existing datastore) otherwise, normal filesystem scan is performed (which writes creating a new datastore).
A better option can be adding a new Hint option to select between the modes f.e.:
- fs
[the ImageMosaic create the datastore scanning the passed folder as usually] - datastore
[the imagemosaic scan the datastore schema for coverages (typeNames) and recursively coverages (typeNames) for granules. Empty tables creates an empty coverage see http://jira.codehaus.org/browse/GEOT-4597] - auto
[ use ‘source’ and old method to create the mosaic reader. This should be the default to preserve old workflow ]
Once the ‘datastore’ mode is selected the DataStore is created and the typeNames will be queried for granules as the ImageMosaicWalker does for the folders. Note that the ImageMosaic base dir (Hints.MOSAIC_LOCATION_ATTRIBUTE) will contain a list of folder representing typenames.
Other options can be added to recalculate the bbox for each granule.
Feedback are really appreciated
Carlo
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
mobile: +39 3371094494
