[Geoserver-devel] Build not running on Intellij
I’m trying to run geoserver from within Intellij to help with debugging. I’m following the instructions listed here https://docs.geoserver.org/latest/en/developer/quickstart/intellij.html
My devel machine is a windows 10 machine.
With the configuration including
Main class: org.geoserver.web.Start
VM options: -DskipTests
Working directory: C:\Users\userName\source\geoserver\src\web\app
Use classpath of module: gs-web-app
JRE: Default(1.8)
When running this configuration. I get the below error. Is there something else I should be doing to get it to run from the IDEA start or debug button?
21 Nov 16:11:49 WARN [webapp.WebAppContext] - Failed startup of context o.e.j.w.WebAppContext@anonymised.com{/geoserver,file:/C:/Users/username/source/geoserver/src/web/app/src/main/webapp/,null}{src/main/webapp}
java.io.IOException: Server returned HTTP response code: 403 for URL: http://www.oracle.com/webfolder/technetwork/jsc/dtd/web-app_2_3.dtd
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1894)
that’s a strange error, I never saw it, looks like the IDE is not able to access:
If you try to access the URL above whit your browser does it works ? It should.
Are you behind a proxy ?
You configuration looks good, although you don’t need the -DskipTests option, I’m sharing with you my default configuration for GeoServer:
Hope it helps,
Nuno Oliveira
JRE: Default(1.8)
21 Nov 16:11:49 WARN [webapp.WebAppContext] - Failed startup of context o.e.j.w.WebAppContext@anonymised.com2…{/geoserver,file:/C:/Users/username/source/geoserver/src/web/app/src/main/webapp/,null}{src/main/webapp}
java.io.IOException: Server returned HTTP response code: 403 for URL:http://www.oracle.com/webfolder/technetwork/jsc/dtd/web-app_2_3.dtd
Geoserver-devel mailing list
[Geoserver-devel@anonymised.comsts.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the
experts!
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:      +39 0584 1660272
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
I essentially have everything the same except for the jetty port and I use the default data dir. When you say I don’t need the -DskipTests, is that because it is only used while building?
~Thomas
On Tue, Nov 27, 2018 at 2:27 AM Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
Hope it helps,
Nuno Oliveira
JRE: Default(1.8)
21 Nov 16:11:49 WARN [webapp.WebAppContext] - Failed startup of context o.e.j.w.WebAppContext@anonymised.com.5302…{/geoserver,file:/C:/Users/username/source/geoserver/src/web/app/src/main/webapp/,null}{src/main/webapp}
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Nuno Oliveira
experts!
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
(attachments)
Yes, this is an option that is only relevant to Maven.
Well in that case I can only suggest you try to understand why your IDE is not able to access:
Nuno Oliveira
@nmcoliveira
Software Engineer
I have gotten everything working by cleaning everything and then the errors changed. I have also solved those issues.
Thomas
On Tue, Nov 27, 2018 at 10:16 AM Nuno Oliveira GeoSolutions <nuno.oliveira@anonymised.com> wrote:
~Thomas
Hope it helps,
Nuno Oliveira
JRE: Default(1.8)
Nuno Oliveira
experts!
@nmcoliveira
Software Engineer
Nuno Oliveira
@nmcoliveira
Software Engineer
Glad to hear it!
Nuno Oliveira
@nmcoliveira
Software Engineer
