[Geoserver-devel] Build of master branch fails when using the geofence-server profile
On the mvn command line use –P geofence-server and the build will fail to compile as it can’t find the org.restlet.resource package. I fixed the error by inserting this into …community\geofence\pom.xml…
org.restlet
org.restlet
On Tue, May 9, 2017 at 10:03 AM, Walter Stovall <walter.stovall@anonymised.com>
        <dependency>
         <groupId>org.restlet</groupId>
         <artifactId>org.restlet</artifactId>
        </dependency>
We have migrated away from restlet in this code sprint:
http://blog.geoserver.org/2017/04/11/rest-api-code-sprint-results/
After the code sprint we disabled a number of community modules because
we could not migrate them, but some have been migrated and re-enabled in
the meantime...
geofence is not one of them though, I see it's still commented out
(geofence-server has
been migrated instead):
https://github.com/geoserver/geoserver/blob/master/src/community/pom.xml#L217
So, it's best not to add back restlet (it's not supported anymore), but
switch whatever
code there is in the geofence module from restlet to spring-mvc.
Patches welcomed :-p
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
