[Geoserver-devel] Build on travis failing again due to too long log
[https://s3.amazonaws.com/archive.travis-ci.org/jobs/17985779/log.txt](https://s3.amazonaws.com/archive.travis-ci.org/jobs/17985779/log.txt)
Sigh... suggestions? Can we silence Maven download reports?
Also, the app-schema tests seem to be super verbose
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Some gwc tests seem to be print out an entire raster
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-gwc ---
NCOLS 120
NROWS 240
XLLCORNER 145.0
YLLCORNER -42.999999999986805
CELLSIZE 0.008333333333313438
NODATA_VALUE -9999
5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 50.0 50.0 50.0 50.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
....etc...
Several tests are printing out the entire GetCapabilities (complete with SRS list):
* org.geoserver.test.WmsGetFeatureInfoTest testGetCapabilities
* org.geoserver.wps.process.WPSConfigProcessFilterTest
* org.geoserver.test.DuplicatePropertiesWfsTest testGetCapabilities
Jody Garnett
On Sat, Feb 1, 2014 at 7:08 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
WatchGuard Dimension instantly turns raw network data into actionable
security intelligence. It gives you real-time visual feedback on key
security issues and trends. Skip the complicated setup - simply import
a virtual appliance and go from zero to informed in seconds.
http://pubads.g.doubleclick.net/gampad/clk?id=123612991&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
This is normally done by running Maven in batch mode with the "-B" option. I use this option on all CI jobs I manage.
They are much quieter than before. We can make them even quieter.
Rini, a small change to AbstractAppSchemaTestSupport.prettyString would hide most response documents from the logs. I am thinking a system property that developers could enable if they want to see them.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
On Mon, Feb 3, 2014 at 4:52 AM, Ben Caradoc-Davies <
Pretty interesting, I'll add it to the GeoServer Travis builds!
I believe there is already a system variable you can peek at to see if the
tests are to be run in quiet mode, which is normally set
as you build with Maven, but not if you run the tests from IDE.
GeoServerBaseTestSupport.isQuietTests()
     * Checks for existence of a system property named "quietTests".
    public static boolean isQuietTests() {
        String quietTests = System.getProperty("quietTests");
        return quietTests != null && !"false".equalsIgnoreCase(quietTests);
I guess you can just call the method above.
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
the tests are to be run in quiet mode, which is normally set
Excellent! I was just re-inventing the wheel, but much better to use the existing flag. I will also need to adjust our poms to ensure the flag is passed by surefire-plugin.
Kind regards,
Software Engineer
On Mon, Feb 3, 2014 at 9:35 AM, Ben Caradoc-Davies <
That flag is sent down to surefire in the main pom for all the module to
use.
Maybe you have customized the app-schema pom already, breaking inheritance?
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
use.
That is exactly what the problem was. Fixed, and no code changes required. Although there are still a few leaky tests, which are now much more obvious. Thanks again!
Kind regards,
Software Engineer
Hey Ben,
the flag helped, we're back with a partially working build:
https://travis-ci.org/geoserver/geoserver/builds/18117677
The Oracle JDK build is still failing with a WPS test failure, but that's
"ok"
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
On 03/02/14 18:25, Andrea Aime wrote:
Hey Ben,
Great! The app-schema quietTests should give you more head room.
Kind regards,
Software Engineer
