I thought
mvn clean install -Doracle.jdbc
should do the job.
But it does not, I tried on trunk and 2.6.x
Any ideas ?
I thought
should do the job.
Any ideas ?
This was probably targeted at the geotools list i assume?
Anyways, the oracle (and other jdbc tests) are not set up with the gt online test framework. I did whip up a patch some time ago but it still needs a bit of work:
http://jira.codehaus.org/browse/GEOT-1981
Anyways, so to run the tests you will have to manually edit the ds.properties, db.properties, and factory.properties to point at an oracle install. Once the connection can be made the tests should execute.
I can't remember off the top of my head but i think you may also need to update the pom.xml so that the jdbc driver is loaded after manully installing it in your local maven repo.
-Justin
Christian Müller wrote:
I thought
should do the job.
Any ideas ?
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Yeah, one has to install the driver in a specific location (instructions
are inside the pom.xml file of the oracle module) and then use the
-Doracle flag to enable its usage
Andrea Aime
I see the problem. I looked at the developers guide
http://docs.codehaus.org/display/GEOT/4+Oracle+Optional+Dependency
There is an example using the property -Doracle.jdbc
mvn eclipse:eclipse -Doracle.jdbc
But looking into the pom, it must be -Doracle
@Andrea, can you fix this in the wiki after you have seen the problem.
Andrea Aime writes:
-Doracle flag to enable its usageCheers
Andrea--
Andrea Aime
mvn eclipse:eclipse -Doracle.jdbcBut looking into the pom, it must be -Doracle
Done (hopefully):
If there is still any problem with that page just go and fix it directly.
Ah, one thing about the Oracle tests: there is a single test failing
in the module, which is actually a problem in the way the test against
views with primary keys is written, that I've never came around to
fix for good.
Just so you know, if you have just a single failure in your setup,
it's not your fault. I have to try to find the time to solve it, but
atm I'm really full of work for other stuff and the doctor already
ordered me a full stop recently because I was too stressed out....
Andrea Aime
