Build server is down, I have not been able to recover/restart, in communication with Juan / Torben / Alessandro to recover?
Jody Garnett
Jody Garnett
Looks like it’s up and running now. Thanks to whoever helped kick it back into action!
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
