[Geoserver-devel] Build Server Maintenance Window
Hi Devs,
This is to inform you that the build server https://build.geoserver.org/ will be unavailable for scheduled maintenance starting on Friday
June 3 at 17:00 UTC. We’ll let you know when it’s back online.
Regards, Alessandro Parma == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Alessandro Parma DevOps Engineer GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) Italy phone: +39 340 4752467 fax: +39 0584 1660272 https://www.geosolutionsgroup.com https://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi again. Just to report that the service is back online.
Alessandro
On Wed, Jun 1, 2022 at 2:16 PM Alessandro Parma <alessandro.parma@anonymised.com6887…> wrote:
Hi Devs,
