This email is to inform us that we’ll be carrying on maintenance operations on the official build server at https://build.geoserver.org/ today and will be mostly unavailable.
I’ll inform you when the operations are finished.
Sorry for the inconvenience
Alessandro
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Alessandro Parma DevOps Engineer GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) Italy phone: +39 340 4752467 fax: +39 0584 1660272 https://www.geosolutionsgroup.comhttps://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Alessandro
Regards, Alessandro Parma == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Alessandro Parma DevOps Engineer GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) Italy phone: +39 340 4752467 fax: +39 0584 1660272 https://www.geosolutionsgroup.comhttps://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
So what happens next? When the new build server is available do we just change the domain over…
While GeoServer 1.20.4 scheduled for next week we do not have a release volunteer for this month. Doing the a maintenance release would be a good test of the new server.
I just came back from the holidays. We’re ready to move on with the switch, I’ll arrange the DNS record updates with the relevant person.
Alessandro
