[Geoserver-devel] Build server: mind if we install the build rerun plugin?
working on the release we had to rerun builds a few times, I was looking for a “rerun this build” command
and could not find it… probably because it’s a functionality provided by a plugin that’s not on the server!
Mind if we install this one?
https://plugins.jenkins.io/rebuild/
Avoids having to re-fill build parameters when one just wants to re-run exactly the same parameterized build.
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
That sounds fine, you are an admin and this our server :slight_smile:
I guess this is only useful when debugging the build scripts … which is a common frustrating activity :stuck_out_tongue:
Jody Garnett
With great power comes great responsibility! So, we though of asking before doing :smiley:
Yep… see also mail in gt-devel about the re-runs.
