[Geoserver-devel] Build Server SSL Cert
Hi All,
Looks like the build server certificate has expired, let me know if I can help with fixing it.
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Alessandro Parma
DevOps Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thanks for the heads-up, I should be able to fix this one, please stand by…
Torben
On Mon, Dec 9, 2019 at 1:45 AM Alessandro Parma <alessandro.parma@anonymised.com> wrote:
Hi All,
Alessandro Parma
Alessandro Parma
DevOps Engineer
Geoserver-devel mailing list
Should be fixed now, please let me know if it is still showing as invalid for you.
Torben
On Mon, Dec 9, 2019 at 3:03 PM Torben Barsballe <torbenbarsballe@anonymised.com> wrote:
Torben
On Mon, Dec 9, 2019 at 1:45 AM Alessandro Parma <alessandro.parma@anonymised.com.> wrote:
Hi All,
Alessandro Parma
Alessandro Parma
DevOps Engineer
Hi Torben,
Yes, looking good thanks
(attachments)
Alessandro Parma
Alessandro Parma
DevOps Engineer
