the build server seems to be in trouble, I’ve already killed a couple of builds but it seems it just gets stuck later in some other build after (not the one right next to it, but after a bit).
The geoserver-master one I’ve just killed was stuck here:
[INFO] Executed tasks
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web-app ---
[INFO] Installing /var/lib/hudson/jobs/geoserver-master/workspace/src/web/app/target/web-app-2.4-SNAPSHOT.jar to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.4-SNAPSHOT/web-app-2.4-SNAPSHOT.jar
[INFO] Installing /var/lib/hudson/jobs/geoserver-master/workspace/src/web/app/pom.xml to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.4-SNAPSHOT/web-app-2.4-SNAPSHOT.pom
[INFO] Installing /var/lib/hudson/jobs/geoserver-master/workspace/src/web/app/target/web-app-2.4-SNAPSHOT-tests.jar to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.4-SNAPSHOT/web-app-2.4-SNAPSHOT-tests.jar
[INFO] Installing /var/lib/hudson/jobs/geoserver-master/workspace/src/web/app/target/web-app-2.4-SNAPSHOT-test-sources.jar to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.4-SNAPSHOT/web-app-2.4-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [web-app] in [/var/lib/hudson/jobs/geoserver-master/workspace/src/web/app/target/geoserver]
[INFO] Processing war project
[INFO] Copying webapp resources [/var/lib/hudson/jobs/geoserver-master/workspace/src/web/app/src/main/webapp]
[INFO] Webapp assembled in [2517 msecs]
[INFO] Building war: /var/lib/hudson/jobs/geoserver-master/workspace/src/web/app/target/geoserver.war
Yesterday I killed the WFS 1.0 cite tests instead
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for the heads up. I’ll keep an eye on it and bounce hudson if it keeps up.
On Mon, Jun 10, 2013 at 6:03 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
[INFO]
[INFO]
Ing. Andrea Aime
@geowolf
Technical Lead
How ServiceNow helps IT people transform IT departments:
- A cloud service to automate IT design, transition and operations
- Dashboards that offer high-level views of enterprise services
- A single system of record for all IT processes
http://p.sf.net/sfu/servicenow-d2d-j
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
