Dear Sir:
I download sourcecode of Geoserver 2.0.1 and build it with maven. But I get following errors. How to rebuild it?
I also want to use web to view maps. How to build a project with web servers to view maps using jdeveloper?
Sincerely
gml:outerBoundaryIs
gml:LinearRing
<gml:coordinates cs=“,” decimal=“.” ts=" " xmlns:gml=“http://www.opengis.net/gml
“>500000,500000 500000,500100 500100,500100 500100,500000 500000,500000</gml:coo
rdinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
<gml:Point srsName=“http://www.opengis.net/gml/srs/epsg.xml#32615”>
<gml:coordinates cs=”,” decimal=“.” ts=" " xmlns:gml=“http://www.opengis.net/gml
“>500050,500050</gml:coordinates>
</gml:Point>
</cdf:pointProperty>
</cdf:Fifteen>
</gml:featureMember>
gml:featureMember
<cdf:Fifteen fid=“Fifteen.5”>
cdf:boundedBy
<gml:Polygon srsName=“http://www.opengis.net/gml/srs/epsg.xml#32615”>
gml:outerBoundaryIs
gml:LinearRing
rdinates>
</gml:LinearRing>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
</gml:Point>
</cdf:Fifteen>
gml:featureMember
<cdf:Fifteen fid=“Fifteen.6”>
cdf:boundedBy
gml:outerBoundaryIs
gml:LinearRing
rdinates>
</gml:LinearRing>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
</gml:Point>
</cdf:Fifteen>
gml:featureMember
<cdf:Fifteen fid=“Fifteen.7”>
cdf:boundedBy
gml:outerBoundaryIs
gml:LinearRing
rdinates>
</gml:LinearRing>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
</gml:Point>
</cdf:Fifteen>
gml:featureMember
<cdf:Fifteen fid=“Fifteen.8”>
cdf:boundedBy
gml:outerBoundaryIs
gml:LinearRing
rdinates>
</gml:LinearRing>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
</gml:Point>
</cdf:Fifteen>
gml:featureMember
<cdf:Fifteen fid=“Fifteen.9”>
cdf:boundedBy
gml:outerBoundaryIs
gml:LinearRing
rdinates>
</gml:LinearRing>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
</gml:Point>
</cdf:Fifteen>
gml:featureMember
<cdf:Fifteen fid=“Fifteen.10”>
cdf:boundedBy
gml:outerBoundaryIs
gml:LinearRing
rdinates>
</gml:LinearRing>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
</gml:Point>
</cdf:Fifteen>
gml:featureMember
<cdf:Fifteen fid=“Fifteen.11”>
cdf:boundedBy
gml:outerBoundaryIs
gml:LinearRing
rdinates>
</gml:LinearRing>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
</gml:Point>
</cdf:Fifteen>
gml:featureMember
<cdf:Fifteen fid=“Fifteen.12”>
cdf:boundedBy
gml:outerBoundaryIs
gml:LinearRing
rdinates>
</gml:LinearRing>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
</gml:Point>
</cdf:Fifteen>
gml:featureMember
<cdf:Fifteen fid=“Fifteen.13”>
cdf:boundedBy
gml:outerBoundaryIs
gml:LinearRing
rdinates>
</gml:LinearRing>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
</gml:Point>
</cdf:Fifteen>
gml:featureMember
<cdf:Fifteen fid=“Fifteen.14”>
cdf:boundedBy
gml:outerBoundaryIs
gml:LinearRing
rdinates>
</gml:LinearRing>
</gml:Polygon>
</cdf:boundedBy>
cdf:pointProperty
<gml:coordinates cs=”,” decimal=“.” ts=" " xmlns:gml="http://www.opengis.net/gml
">500050,500050</gml:coordinates>
</gml:Point>
</cdf:Fifteen>
</wfs:FeatureCollection>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.187 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.594 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.625 sec
Running org.geoserver.wfs.v1_1.GetCapabilitiesTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.656 sec
Running org.geoserver.wfs.ReprojectionWriteTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.5 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
2010-3-22 10:30:22 org.geoserver.data.util.IOUtils emptyDirectory
¾¯¸æ: Could not delete F:\software\GeoServerSourceCode\geoserver-2.0.1-src\geose
rver-2.0.1\wfs.\target\mock3461565623092276750data\sf\PrimitiveGeoFeature.prope
rties
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.25 sec
Running org.geoserver.wfs.AliasTest
<xsd:schema xmlns:xsd=“http://www.w3.org/2001/XMLSchema” xmlns:cdf=“http://www.o
pengis.net/cite/data” xmlns:gml=“http://www.opengis.net/gml” elementFormDefault=
“qualified” targetNamespace=“http://www.opengis.net/cite/data”>
<xsd:import namespace=“http://www.opengis.net/gml” schemaLocation=“http://loca
lhost:80/geoserver/schemas/gml/2.1.2/feature.xsd”/>
<xsd:complexType name=“ft15Type”>
xsd:complexContent
<xsd:extension base=“gml:AbstractFeatureType”>
xsd:sequence
<xsd:element maxOccurs=“1” minOccurs=“0” name=“boundedBy” nillable=“tr
ue” type=“gml:PolygonPropertyType”/>
<xsd:element maxOccurs=“1” minOccurs=“0” name=“pointProperty” nillable
=“true” type=“gml:PointPropertyType”/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name=“ft15” substitutionGroup=“gml:_Feature” type=“cdf:ft15Type”/
</xsd:schema>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
2010-3-22 10:30:24 org.geoserver.data.util.IOUtils emptyDirectory
rver-2.0.1\wfs.\target\mock6701910993012049309data\cite\BasicPolygons.propertie
s
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.609 sec
Running org.geoserver.wfs.SrsNameTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.516 sec
Results :
Tests in error:
testPostMissingType10(org.geoserver.wfs.GetFeatureMissingTypesTest)
testPostMissingType11(org.geoserver.wfs.GetFeatureMissingTypesTest)
Tests run: 178, Failures: 0, Errors: 2, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to F:\software\GeoServerSourceCode\geoserver-2.0.1-src\geoserver-2.
0.1\wfs\target\surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 19 seconds
[INFO] Finished at: Mon Mar 22 10:30:25 CST 2010
[INFO] Final Memory: 37M/63M
F:\software\GeoServerSourceCode\geoserver-2.0.1-src\geoserver-2.0.1>
F:\software\GeoServerSourceCode\geoserver-2.0.1-src\geoserver-2.0.1>mvn -e
- Error stacktraces are turned on.
[INFO] Scanning for projects…
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Configuration Deployment PlugIn
[INFO] GeoServer Maven Archetypes
[INFO] GeoServer Web Plugin Archetype
[INFO] GeoServer WFS Output Format Archetype
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] WCS UI Module
[INFO] Demoes Module
[INFO] Security UI Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] GeoServer Extensions
[INFO]
You must specify at least one goal. Try ‘mvn install’ to build or ‘mvn --help’ f
or options
See http://maven.apache.org for more information.
[INFO] Trace
org.apache.maven.BuildFailureException:
or options
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLi
fecycleExecutor.java:134)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:345)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:132)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:290)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
[INFO] Total time: 1 second
[INFO] Finished at: Mon Mar 22 10:53:55 CST 2010
[INFO] Final Memory: 6M/11M
F:\software\GeoServerSourceCode\geoserver-2.0.1-src\geoserver-2.0.1>mvn e
[INFO] GeoServer
[INFO] Main Module
[INFO] Invalid task ‘e’: you must specify a valid lifecycle phase, or a goal in
the format plugin:goal or pluginGroupId:pluginArtifactId:pluginVersion:goal
[INFO] Finished at: Mon Mar 22 10:54:09 CST 2010
[INFO] GeoServer
[INFO] Main Module
[INFO]
or options
[INFO] Trace
or options
java:39)
sorImpl.java:25)
[INFO] Finished at: Mon Mar 22 10:54:55 CST 2010
[INFO] GeoServer
[INFO] Main Module
[INFO]
or options
[INFO] Finished at: Mon Mar 22 10:55:34 CST 2010
[INFO] GeoServer
[INFO] Main Module
[INFO]
or options
[INFO] Trace
or options
java:39)
sorImpl.java:25)
[INFO] Finished at: Mon Mar 22 10:55:44 CST 2010
ʹÓÃMessenger±£»¤¶Ü2.0£¬Ö§³Ö¶àÕ˺ŵǼ£¡ ÏÖÔÚ¾ÍÏÂÔØ£¡
