[Geoserver-devel] build.xml -- "geotools" ant target
I made a small modification to build.xml.
If you use the "geotools" ant script that moves the geotools related
.jars to the geoserver lib/ directory, this change might affect you.
I made it so it copied a few more jars and it takes all the jars from
your maven repository.
Before it only moved a few .jars and took some of them from the maven
repository and some from your geotools install.
If you're using it, you should check to make sure its doing what you
expect it to be doing.
If you do not use this ant target, they these changes will not affect
you.
dave
This mail sent through IMP: https://webmail.limegroup.com/
