[Geoserver-devel] Building a Kmeans Image clustering class to geoserver
Hi. I 'm trying to build a Kmeans Image clustering algorithm into WPS service. My project consist of two java classes: the first one contains the actual algorithm and the other contains the DescribeParameter etc. The first class uses JAI and the output image is TiledImage. I have build the project into geoserver and the second class work fine , so i can populate the parameters.When I try to run it , I get a black image as an output(but it doesn’t crashes). The log I get is the following:
2014-04-08 15:27:51,436 INFO [geoserver.wps] -
Request: execute
service = WPS
version = 1.0.0
baseUrl = http://localhost:8080/geoserver/
identifier:
value = gs:Kmeans
dataInputs:
input[0]:
identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com (value: coverage, codeSpace: null)
reference = net.opengis.wps10.impl.InputReferenceTypeImpl@anonymised.com (body: net.opengis.wcs11.impl.GetCoverageTypeImpl@anonymised.com (service: WCS, version: 1.1.1, baseUrl: null, extendedProperties: {}), encoding: null, href: http://geoserver/wcs, method: POST, mimeType: image/tiff, schema: null)input[0]:
identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com (value: number of clusters, codeSpace: null)
data = net.opengis.wps10.impl.DataTypeImpl@anonymised.com[0]:
identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com (value: maximum iterations, codeSpace: null)
identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com (value: epsilon, codeSpace: null)
responseForm:
Note that the algorithm is running well on eclipse and i get the segmented image as expected.
What may I have done wrong?
I 'm running geoserver 2.4.0 with the updated patch main 2.4 - SNAPSHOT
On Tue, Apr 8, 2014 at 2:53 PM, lewnidas sketo <lepa_aun@anonymised.com> wrote:
it doesn't crashes). The log I get is the following:
Request: execute
    service = WPS
    version = 1.0.0
    identifier:
        value = gs:Kmeans
    dataInputs:
        input[0]:
            identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com(value: coverage, codeSpace: null)
            reference =
null)input[0]:
            identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com(value: number of clusters, codeSpace: null)
            identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com(value: maximum iterations, codeSpace: null)
            identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com(value: epsilon, codeSpace: null)
    responseForm:
Don't know, I'd probably try to intercercept the PPIO that is encoding your
image, and see if it's that one, or
if your tiled image has some odd combination of sample model and color
model that the
JAI ImageIO encoders cannot handle well
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
