i try to compile the community/web2 module, but the building failed.
the error is:
Downloading: http://lists.refractions.net/m2//org/geoserver/wfsv/2.0-SNAPSHOT/wfsv-2.0-SNAPSHOT.pom
Downloading: http://lists.refractions.net/m2//org/geoserver/wfsv/2.0-SNAPSHOT/wfsv-2.0-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
- org.geoserver:wfsv:jar:2.0-SNAPSHOT
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.geoserver -DartifactId=wfsv -Dversion=2.0-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.geoserver -DartifactId=wfsv -Dversion=2.0-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
- org.geoserver.web:web-app:jar:2.0-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
refractions (http://lists.refractions.net/m2/),
geotools (http://maven.geotools.fr/repository/),
mortbay (http://www.mortbay.org/maven2/release)
Suggestion?
Francesco Izzi
CNR - IMAA
geoSDI - NSDI
Responsabile Sviluppo Software
C.da Loja
85050 Tito Scalo - POTENZA (PZ)
Italia
phone: +39 0971427305
fax: +39 0971 427271
mob: +39 3402640314
mail: francesco.izzi@anonymised.com
skype: neofx8080
web: http://geosdi.nsdi.it
Hi Francesco,
I believe that web2/app/pom.xml had an error in it in which there was a direct dependency on wfsv, when in fact it should only be engaged via a profile.
I just committed a fix. Can you update and try it again.
-Justin
Francesco Izzi wrote:
the error is:
[ERROR] BUILD ERROR
Missing:
1) org.geoserver:wfsv:jar:2.0-SNAPSHOT
Path to dependency:
1) org.geoserver.web:web-app:jar:2.0-SNAPSHOT
2) org.geoserver:wfsv:jar:2.0-SNAPSHOT
for artifact:
Suggestion?
Francesco Izzi
CNR - IMAA
geoSDI - NSDI
C.da Loja
Italia
mob: +39 3402640314
mail: francesco.izzi@anonymised.com <mailto:francesco.izzi@anonymised.com>
skype: neofx8080
Check out the new SourceForge.net Marketplace.
It is the best place to buy or sell services for
just about anything Open Source.
http://p.sf.net/sfu/Xq1LFB
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Ok woking fine.
Thanks.
2009/1/7 Justin Deoliveira <jdeolive@anonymised.com>
Hi Francesco,
-Justin
the error is:
[ERROR] BUILD ERROR
Missing:
Path to dependency:
for artifact:
Suggestion?
Francesco Izzi
CNR - IMAA
geoSDI - NSDI
C.da Loja
Italia
mob: +39 3402640314
mail: francesco.izzi@anonymised.com mailto:[francesco.izzi@anonymised.com](mailto:francesco.izzi@anonymised.com)
skype: neofx8080
Justin Deoliveira
Francesco Izzi
CNR - IMAA
geoSDI - NSDI
C.da Loja
Italia
mob: +39 3402640314
skype: neofx8080
