HI geoserver-devel,
While we are trying to fix the build error of Geoserver, we found it broke at the Gs-wps-core:WPSXStreamLoaderTest.java line :81(please refer the attached building output) . We tried to debug and found the reason is because file url path for a resources has space character which was encoded with “%20” . then it caused that the resources was not loaded properly and it breaks the test.
So I thought that I might report it to community. Also I added a few line code to fix the problem, please have it for reference.
Lingbo
/////////////////the building output/////////////////////////
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec <<< FAILURE!
testBackFormatXmlComatibility(org.geoserver.wps.WPSXStreamLoaderTest) Time elapsed: 4 sec <<< FAILURE!
java.lang.AssertionError
at org.junit.Assert.fail(Assert.java:86)
at org.junit.Assert.assertTrue(Assert.java:41)
at org.junit.Assert.assertTrue(Assert.java:52)
at org.geoserver.wps.WPSXStreamLoaderTest.testBackFormatXmlComatibility(WPSXStreamLoaderTest.java:81)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
/////////////////////////////// please refer the green line code change///////////////////////////
@Test
public void testBackFormatXmlComatibility() throws Exception {
GeoServer gs = createMock(GeoServer.class);
URL url = Thread.currentThread().getContextClassLoader().getResource(“org/geoserver/wps/”);
//Lingbo the url was encoded with “%20” for space.
+File file;
+try {
file = new File(url.toURI());
} catch(URISyntaxException e) {
file = new File(url.getPath());
-File file = new File(url.getPath());
WPSXStreamLoader loader = new WPSXStreamLoader(new GeoServerResourceLoader(file));
WPSInfo wps = loader.load(gs);
boolean found1 = false;
boolean found2 = false;
for (ProcessGroupInfo pg : wps.getProcessGroups()) {
if (pg.getFactoryClass().getName().equals(“org.geoserver.wps.DeprecatedProcessFactory”)) {
assertFalse(pg.isEnabled());
found1 = true;
if (pg.getFilteredProcesses() != null) {
for (Object opi : pg.getFilteredProcesses()) {
assertTrue(opi instanceof ProcessInfo);
.equals(“org.geoserver.wps.jts.SpringBeanProcessFactory”)) {
assertTrue(pg.isEnabled());
assertEquals(pg.getFilteredProcesses().get(0).getName().toString(),
“gs:GeorectifyCoverage”);
assertEquals(pg.getFilteredProcesses().get(1).getName().toString(),
“gs:GetFullCoverage”);
assertEquals(pg.getFilteredProcesses().get(2).getName().toString(), “gs:Import”);
found2 = true;
assertTrue(found1);
assertTrue(found2);
