Does anyone have advice about a convenient way to build when modifying geotools, such as making changes in the app-schema extension, and then testing with geoserver? I can imagine manually creating a geotools jar and installing that into my maven repository in place of the published geotools jar, but that seems like a lot of work to be doing it many times.
Tara
Tara Athan
Owner, Athan Ecological Reconciliation Services
tara_athan at alt2is.com
707-272-2115 (cell, preferred)
707-485-1198 (office)
249 W. Gobbi St. #A
Ukiah, CA 95482
Hi Tara,
Unfortunately this is the way it is usually done. Some developers in the past i believe have set up eclipse workspaces that have both geoserver and geotools in them bypassing maven. But i usually go through maven dependencies.
A workflow that works well for me is:
- have two eclipse workspaces going at once, once for geotools and once for geoserver
- make a geotoosl change
- compile only teh necessary modules (-DskipTests is your friend here)
- refresh your geoserver workspace
- restart geoserver via Start.java
I find it is not too tedious once you get used to it.
Hope that helps.
-Justin
On Wed, Aug 11, 2010 at 5:36 PM, Tara Athan <taraathan@anonymised.com> wrote:
Tara
Tara Athan
249 W. Gobbi St. #A
Ukiah, CA 95482
This SF.net email is sponsored by
Make an app they can’t live without
Enter the BlackBerry Developer Challenge
http://p.sf.net/sfu/RIM-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira ha scritto:
Hi Tara,
So do I. I've tried to setup a single set of interconnected projects,
but unfortunately that does not work: in Eclipse the test dependencies
of a project are inherited from the dependent projects as well, and
there are some geotools specific test dependencies that do break
the GeoServer own tests, making development sort of impossible.
* have two eclipse workspaces going at once, once for geotools and once for geoserver
* make a geotoosl change
* compile only teh necessary modules (-DskipTests is your friend here)
* refresh your geoserver workspace
* restart geoserver via Start.java
I have a variant of this setup where I have just one Eclipse instance
going and two project groups, one of geotools, and for geoserver,
open in the same workspace. Which yeah, means you have more than 100
projects open in a single Eclipse instance
Andrea Aime
Thanks! OK, I've got this mostly working with two workspaces, except I don't see instructions on how to use Start.java with a different data directory - is that possible? It doesn't seem to be recognising my GEOSERVER_DATA_DIR environment variable.
Also, has anyone had success with any maven-eclipse plugin, or is it better to stick to the command line ( one console for geoserver, one for geotools ... I think I need a second monitor...)
Tara
Hi Tara,
Tara Athan
249 W. Gobbi St. #A
Ukiah, CA 95482
I normally set -DGEOSERVER_DATA_DIR=... in the eclipse launcher,
jvm options section.
You need a better console. If you're on Windows try Console:
http://sourceforge.net/projects/console/
Tara
Hi Tara,
Andrea Aime
Tara, I set GEOSERVER_DATA_DIR in my Eclipse launch configuration.
https://www.seegrid.csiro.au/twiki/bin/view/Infosrvices/GeoserverDevelopmentSetup#Debugging_GeoServer_using_embedd
(that page needs some work)
I'm using Eclipse working sets (one each for GS and GT) and maven command-line.
Tara
Hi Tara,
once for geoserver
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
