[Geoserver-devel] Building Geoserver minimal war
just started playing a bit with geoserver. How do you build the version with minimal configuration?
I see the minimal.zip, basic.zip, cite.zip etc. Properties in the web project but I don't know
how to get a deployable war with these configuration options?
The war:war target leaves me with a 36m war which contains all sorts of sample data etc...
I want to include geoserver in my existing spring-webapp to display some geodata with openlayers.
Nils
to change the configuration you have to specify its name on the -DconfigId Java option.
For example, if you would like to compile GeoServer using the minimal configuration, just write the following command line:
mvn -DconfigId=minimal clean install
Once the process is done, you can find the WAR file into the web/target directory.
On 1/17/07, Nils Liebelt <nils.liebelt@anonymised.com> wrote:
project but I don’t know
sample data etc…
Nils
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-devel mailing list
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
here's is the catalog from the build:
<?config.xml version="1.0" encoding="UTF-8"?>
<catalog>
<datastores>
</datastores>
<namespaces>
</namespaces>
<styles>
</styles>
</catalog>
Nils
Alessio Fabiani schrieb:
Can you send me your WEB-INF/catalog.xml file? I'll send you back a fresh new one which should let you start-up an empty GeoServer
. Moreover be sure to delete every info.xml file you can find into the data directory.
On 1/19/07, *Nils Liebelt* <nils.liebelt@anonymised.com <mailto:nils.liebelt@anonymised.com>> wrote:
    I guess I have to correct myself. The building part was easy but
    left me
    with a war where the context won't start up. But well it was the trunk
    so I checked out the 1.4.0tagged release from
    https://svn.codehaus.org/geoserver/tags/1.4.0/ and run the "mvn
    install"
    on the web-project which terminates succesful but when deployiing on
    Tomcat (apache-tomcat-5.5.20 on the jvm 1.5 sun jre) I get
    following NPE
    (Stacktrace below). So my question how do I build a "running"
    version of
    the geoserver.war?
    Nils
    INFO: Deploying web application archive geoserver.war
    19.01.2007 11:55:19 org.springframework.web.context.ContextLoader
    initWebApplicationContext
    INFO: Root WebApplicationContext: initialization started
    19.01.2007 11:55:19
    org.springframework.beans.factory.xml.XmlBeanDefinitionReader
    loadBeanDefinitions
    INFO: Loading XML bean definitions from URL
    [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/main-1.4.0.jar!/applicationContext.xml]
    19.01.2007 11:55:20
    loadBeanDefinitions
    [file:/opt/tomcat/current/webapps/geoserver/WEB-INF/classes/applicationContext.xml]
    19.01.2007 11:55:20
    loadBeanDefinitions
    [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/data-1.4.0.jar!/applicationContext.xml]
    19.01.2007 11:55:20
    loadBeanDefinitions
    [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/wfs-1.4.0.jar!/applicationContext.xml]
    19.01.2007 11:55:20
    loadBeanDefinitions
    [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/wms-1.4.0.jar!/applicationContext.xml]
    19.01.2007 11:55:20
    loadBeanDefinitions
    [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/validation-1.4.0.jar!/applicationContext.xml]
    19.01.2007 11:55:20
    org.springframework.context.support.AbstractRefreshableApplicationContext
    refreshBeanFactory
    INFO: Bean factory for application context [Root
    WebApplicationContext]:
    org.springframework.beans.factory.support.DefaultListableBeanFactory
    defining beans
    [config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy,applicationState,applicationStateRegisterar,catalog,serviceFinder,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,PNGMapProducerFactory,JAIMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,validation,validationConfig,validationRegisterar,validationConfigRegisterar];
    root of BeanFactory hierarchy
    19.01.2007 11:55:20
    org.springframework.context.support.AbstractApplicationContext refresh
    INFO: 54 beans defined in application context [Root
    19.01.2007 11:55:20 org.springframework.core.CollectionFactory
    <clinit>
    INFO: JDK 1.4+ collections available
    19.01.2007 11:55:20
    initMessageSource
    INFO: Unable to locate MessageSource with name 'messageSource': using
    default
    [org.springframework.context.support.DelegatingMessageSource@anonymised.com..]
    19.01.2007 11:55:20
    initApplicationEventMulticaster
    INFO: Unable to locate ApplicationEventMulticaster with name
    'applicationEventMulticaster': using default
    [org.springframework.context.event.SimpleApplicationEventMulticaster@...1036...
    19.01.2007 11:55:20
    org.springframework.ui.context.support.UiApplicationContextUtils
    initThemeSource
    INFO: Unable to locate ThemeSource with name 'themeSource': using
    default
    [org.springframework.ui.context.support.ResourceBundleThemeSource@anonymised.com1037...
    19.01.2007 11:55:20
    preInstantiateSingletons
    INFO: Pre-instantiating singletons in factory
    [org.springframework.beans.factory.support.DefaultListableBeanFactory
    defining beans
    root of BeanFactory hierarchy]
    19.01.2007 11:55:20 org.vfny.geoserver.global.xml.XMLConfigReader
    loadGlobal
    KONFIG: logging level is CONFIG
    loadGlobal
    KONFIG: maxFeatures is 1000000
    loadGlobal
    KONFIG: numDecimals returning is 8
    loadGlobal
    KONFIG: charSet is UTF-8
    loadWFS
    KONFIG: reading srsXmlStyle: [srsXmlStyle: null]
    loadBaseMapLayers
    INFO: No baseMap groups defined yet
    loadCatalog
    KONFIG: Loading configuration file:
    /opt/tomcat/current/webapps/geoserver/WEB-INF/catalog.xml
    19.01.2007 11:55:20
    org.springframework.beans.factory.support.AbstractBeanFactory
    destroySingletons
    INFO: Destroying singletons in factory
    {org.springframework.beans.factory.support.DefaultListableBeanFactory
    defining beans
    root of BeanFactory hierarchy}
    19.01.2007 11:55:20 org.springframework.web.context.ContextLoader
    SCHWERWIEGEND: Context initialization failed
    org.springframework.beans.factory.BeanCreationException : Error
    creating
    bean with name 'config' defined in URL
    [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/main-1.4.0.jar!/applicationContext.xml]:
    Initialization of bean failed; nested exception is
    org.springframework.beans.factory.BeanInitializationException: Error
    creating xml config reader; nested exception is
    org.vfny.geoserver.global.ConfigurationException:
    java.lang.NullPointerException
    org.springframework.beans.factory.BeanInitializationException : Error
        at
    org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:300)
        at
    org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:195)
        at
    .<init>(XMLConfigReader.java:145)
        at
    org.vfny.geoserver.global.Config.setApplicationContext(Config.java:43)
        at
    org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization
    (ApplicationContextAwareProcessor.java:84)
        at
    org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:248)
        at
    org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:362)
        at
    org.springframework.beans.factory.support.AbstractBeanFactory.getBean
    (AbstractBeanFactory.java:226)
        at
    org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
        at
    org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons
    (DefaultListableBeanFactory.java:275)
        at
    org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:318)
        at
    org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh
    (AbstractRefreshableWebApplicationContext.java:134)
        at
    org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
        at
    org.springframework.web.context.ContextLoader.initWebApplicationContext
    (ContextLoader.java:156)
        at
    org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
        at
    org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java
    :3763)
        at
    org.apache.catalina.core.StandardContext.start(StandardContext.java:4211)
        at
    org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:759)
        at
    (ContainerBase.java:739)
        at
    org.apache.catalina.core.StandardHost.addChild(StandardHost.java:524)
        at
    org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809)
        at
    org.apache.catalina.startup.HostConfig.deployWARs
    (HostConfig.java:698)
        at
    org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:472)
        at
    org.apache.catalina.startup.HostConfig.start(HostConfig.java:1122)
        at
    org.apache.catalina.startup.HostConfig.lifecycleEvent
    (HostConfig.java:310)
        at
    org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
        at
    org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1021)
        at org.apache.catalina.core.StandardHost.start
    (StandardHost.java:718)
        at
    org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1013)
        at
    org.apache.catalina.core.StandardEngine.start(StandardEngine.java:442)
        at
    org.apache.catalina.core.StandardService.start
    (StandardService.java:450)
        at
    org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
        at org.apache.catalina.startup.Catalina.start(Catalina.java:551)
        at sun.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
        at
    sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at
    sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke (Method.java:585)
        at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:294)
        at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:432)
    Caused by: java.lang.NullPointerException
        at
    org.vfny.geoserver.global.xml.XMLConfigReader.loadFeatureTypes(XMLConfigReader.java:1024)
        at
    org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:297)
        ... 38 more
    19.01.2007 11:55:20 org.apache.catalina.core.StandardContext start
    SCHWERWIEGEND: Error listenerStart
    > Yes, but you have to manually edit the GeoServer config files.
    > However it depends on what kind of data you need to handle.
    Consider
    > that the GeoServer WMS uses the WFS as vectorial data provider and
    > WCS as raster data provider; so you cannot have just the WMS service
    > up, you need at least one of the others too.
    > Remember that using the GEOSERVER_DATA_DIR environment variable,
    which
    > can be setted even inside the web.xml, you can move all the
    > data to another path, and leave on the server just the core
    libraries
    > and code.
    > On 1/17/07, *Nils Liebelt* < nils.liebelt@anonymised.com
    > <mailto:nils.liebelt@anonymised.com
    <mailto:nils.liebelt@anonymised.com>>> wrote:
    > Hi,
    > that worked well! But I have to strap it a bit more. I see
    all those
    > struts config for the WebGui etc. I don't need it that. All
    I want
    > to do
    > is make my webapp respond to few wms-urls. Is there like a
    minimal
    > ApplicationContext or web.xml . I could just use as starting
    point?
    > Regards,
    > Nils
    > Alessio Fabiani schrieb:
    > > Hi,
    > > to change the configuration you have to specify its name
    on the
    > > -DconfigId Java option.
    > > For example, if you would like to compile GeoServer using the
    > minimal
    > > configuration, just write the following command line:
    > > mvn -DconfigId=minimal clean install
    > > Once the process is done, you can find the WAR file into the
    > > web/target directory.
    > > On 1/17/07, *Nils Liebelt* < nils.liebelt@anonymised.com
    > > <mailto: nils.liebelt@anonymised.com
    <mailto:nils.liebelt@anonymised.com>>>> wrote:
    > > Hi,
    > > just started playing a bit with geoserver. How do you
    build the
    > > version
    > > with minimal configuration?
    > > I see the minimal.zip, basic.zip, cite.zip etc. Properties
    > in the web
    > > project but I don't know
    > > how to get a deployable war with these configuration
    options?
    > > The war:war target leaves me with a 36m war which
    contains all
    > > sorts of
    > > sample data etc...
    > > I want to include geoserver in my existing
    spring-webapp to
    > > display some
    > > geodata with openlayers.
    > > Regards,
    > > Nils
    > > Take Surveys. Earn Cash. Influence the Future of IT
    > > Join SourceForge.net's Techsay panel and you'll get the
    > chance to
    > > share your
    > > opinions on IT & business topics through brief surveys
    - and
    > earn
    > > cash
    > http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
    <http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV&gt;
    > <http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
    <http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV&gt;&gt;
    <http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV&gt;&gt;&gt;
    > > _______________________________________________
    > > Geoserver-devel mailing list
    > > Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>
    > <mailto:Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>>
    > > <mailto:Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>>>
    > > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
    https://lists.sourceforge.net/lists/listinfo/geoserver-devel&gt;
    > > Eng. Alessio Fabiani
    > > Vice President/CTO GeoSolutions
    > > http://www.geo-solutions.it < http://www.geo-solutions.it>
