I guess I have to correct myself. The building part was easy but left me with a war where the context won't start up. But well it was the trunk so I checked out the 1.4.0tagged release from https://svn.codehaus.org/geoserver/tags/1.4.0/ and run the "mvn install" on the web-project which terminates succesful but when deployiing on Tomcat (apache-tomcat-5.5.20 on the jvm 1.5 sun jre) I get following NPE (Stacktrace below). So my question how do I build a "running" version of the geoserver.war?
Nils
INFO: Deploying web application archive geoserver.war
19.01.2007 11:55:19 org.springframework.web.context.ContextLoader initWebApplicationContext
INFO: Root WebApplicationContext: initialization started
19.01.2007 11:55:19 org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/main-1.4.0.jar!/applicationContext.xml]
19.01.2007 11:55:20 org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [file:/opt/tomcat/current/webapps/geoserver/WEB-INF/classes/applicationContext.xml]
INFO: Loading XML bean definitions from URL [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/data-1.4.0.jar!/applicationContext.xml]
INFO: Loading XML bean definitions from URL [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/wfs-1.4.0.jar!/applicationContext.xml]
INFO: Loading XML bean definitions from URL [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/wms-1.4.0.jar!/applicationContext.xml]
INFO: Loading XML bean definitions from URL [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/validation-1.4.0.jar!/applicationContext.xml]
19.01.2007 11:55:20 org.springframework.context.support.AbstractRefreshableApplicationContext refreshBeanFactory
INFO: Bean factory for application context [Root WebApplicationContext]: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy,applicationState,applicationStateRegisterar,catalog,serviceFinder,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,PNGMapProducerFactory,JAIMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,validation,validationConfig,validationRegisterar,validationConfigRegisterar]; root of BeanFactory hierarchy
19.01.2007 11:55:20 org.springframework.context.support.AbstractApplicationContext refresh
INFO: 54 beans defined in application context [Root WebApplicationContext]
19.01.2007 11:55:20 org.springframework.core.CollectionFactory <clinit>
INFO: JDK 1.4+ collections available
19.01.2007 11:55:20 org.springframework.context.support.AbstractApplicationContext initMessageSource
INFO: Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@anonymised.com]
19.01.2007 11:55:20 org.springframework.context.support.AbstractApplicationContext initApplicationEventMulticaster
INFO: Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@anonymised.com6...]
19.01.2007 11:55:20 org.springframework.ui.context.support.UiApplicationContextUtils initThemeSource
INFO: Unable to locate ThemeSource with name 'themeSource': using default [org.springframework.ui.context.support.ResourceBundleThemeSource@anonymised.com.]
19.01.2007 11:55:20 org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in factory [org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy,applicationState,applicationStateRegisterar,catalog,serviceFinder,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,PNGMapProducerFactory,JAIMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,validation,validationConfig,validationRegisterar,validationConfigRegisterar]; root of BeanFactory hierarchy]
19.01.2007 11:55:20 org.vfny.geoserver.global.xml.XMLConfigReader loadGlobal
KONFIG: logging level is CONFIG
KONFIG: maxFeatures is 1000000
KONFIG: numDecimals returning is 8
KONFIG: charSet is UTF-8
19.01.2007 11:55:20 org.vfny.geoserver.global.xml.XMLConfigReader loadWFS
KONFIG: reading srsXmlStyle: [srsXmlStyle: null]
19.01.2007 11:55:20 org.vfny.geoserver.global.xml.XMLConfigReader loadBaseMapLayers
INFO: No baseMap groups defined yet
19.01.2007 11:55:20 org.vfny.geoserver.global.xml.XMLConfigReader loadCatalog
KONFIG: Loading configuration file: /opt/tomcat/current/webapps/geoserver/WEB-INF/catalog.xml
19.01.2007 11:55:20 org.springframework.beans.factory.support.AbstractBeanFactory destroySingletons
INFO: Destroying singletons in factory {org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy,applicationState,applicationStateRegisterar,catalog,serviceFinder,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,PNGMapProducerFactory,JAIMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,validation,validationConfig,validationRegisterar,validationConfigRegisterar]; root of BeanFactory hierarchy}
19.01.2007 11:55:20 org.springframework.web.context.ContextLoader initWebApplicationContext
SCHWERWIEGEND: Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'config' defined in URL [jar:file:/opt/tomcat/current/webapps/geoserver/WEB-INF/lib/main-1.4.0.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanInitializationException: Error creating xml config reader; nested exception is org.vfny.geoserver.global.ConfigurationException: java.lang.NullPointerException
at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:300)
at org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:195)
at org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:145)
at org.vfny.geoserver.global.Config.setApplicationContext(Config.java:43)
at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:84)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:248)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:362)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:226)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:275)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:318)
at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:156)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3763)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4211)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:759)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:739)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:524)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:698)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:472)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1122)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:310)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1021)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:718)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1013)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:442)
at org.apache.catalina.core.StandardService.start(StandardService.java:450)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
at org.apache.catalina.startup.Catalina.start(Catalina.java:551)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:294)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:432)
Caused by: java.lang.NullPointerException
at org.vfny.geoserver.global.xml.XMLConfigReader.loadFeatureTypes(XMLConfigReader.java:1024)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:297)
... 38 more
19.01.2007 11:55:20 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error listenerStart
Alessio Fabiani schrieb:
Yes, but you have to manually edit the GeoServer config files.
However it depends on what kind of data you need to handle. Consider that the GeoServer WMS uses the WFS as vectorial data provider and WCS as raster data provider; so you cannot have just the WMS service up, you need at least one of the others too.
Remember that using the GEOSERVER_DATA_DIR environment variable, which can be setted even inside the web.xml, you can move all the GeoServer data to another path, and leave on the server just the core libraries and code.On 1/17/07, *Nils Liebelt* <nils.liebelt@anonymised.com <mailto:nils.liebelt@anonymised.com>> wrote:
that worked well! But I have to strap it a bit more. I see all those
struts config for the WebGui etc. I don't need it that. All I want
to do
is make my webapp respond to few wms-urls. Is there like a minimal
ApplicationContext or web.xml. I could just use as starting point?Regards,
Nils
> Hi,
> to change the configuration you have to specify its name on the
> -DconfigId Java option.
> For example, if you would like to compile GeoServer using the
minimal
> configuration, just write the following command line:
> mvn -DconfigId=minimal clean install
> Once the process is done, you can find the WAR file into the
> web/target directory.
<mailto:nils.liebelt@anonymised.com>>> wrote:
> Hi,
> just started playing a bit with geoserver. How do you build the
> version
> with minimal configuration?
> I see the minimal.zip, basic.zip, cite.zip etc. Properties
in the web
> project but I don't know
> how to get a deployable war with these configuration options?
> The war:war target leaves me with a 36m war which contains all
> sorts of
> sample data etc...
> I want to include geoserver in my existing spring-webapp to
> display some
> geodata with openlayers.
> Regards,
> Nils
> Take Surveys. Earn Cash. Influence the Future of IT
> Join SourceForge.net's Techsay panel and you'll get the
chance to
> share your
> opinions on IT & business topics through brief surveys - and
earn
> cash
> http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
<http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV>> <
<http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV>>> _______________________________________________
> Geoserver-devel mailing list
> Geoserver-devel@lists.sourceforge.net
<mailto:Geoserver-devel@lists.sourceforge.net>
<mailto:Geoserver-devel@lists.sourceforge.net>>
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
> <https://lists.sourceforge.net/lists/listinfo/geoserver-devel>
> Eng. Alessio Fabiani
> Vice President/CTO GeoSolutions
> http://www.geo-solutions.it
Vice President/CTO GeoSolutions---------------------------------------------------------
