Inspired by Jody's comment (during the FOSS4G talk) about testers not checking
the build on JDK 8, I decided to give it a try today.
It turns out that there are few broken tests, but geoserver will build OK with
JDK 8. I only ran the resulting war against a tomcat7 server with OpenJDK7,
but it seemed to start up, at least.
The failing tests appear on the surface to be unrelated, but I think they are
failing because of a common issue - a change on JDK 8 related to the hashing
function. That manifests itself as changing order when a list or map is
serialised out.
Looking at the changes I had to make:
diff --git a/src/kml/src/test/java/org/geoserver/kml/KMLReflectorTest.java b/src/kml/src/test/java/org/geoserver/kml/KMLReflectorTest.java
index 3a085fd..db28359 100644
--- a/src/kml/src/test/java/org/geoserver/kml/KMLReflectorTest.java
+++ b/src/kml/src/test/java/org/geoserver/kml/KMLReflectorTest.java
@@ -24,7 +24,9 @@ import java.io.InputStream;
import java.io.UnsupportedEncodingException;
import java.net.URL;
import java.net.URLDecoder;
+import java.util.Arrays;
import java.util.HashMap;
+import java.util.List;
import java.util.Map;
import java.util.regex.Pattern;
import java.util.zip.ZipEntry;
@@ -252,10 +254,17 @@ public class KMLReflectorTest extends WMSTestSupport {
// all the kvp parameters (which should be set as format_options now are correctly parsed)
String result = xpath.evaluate("//kml:NetworkLink/kml:Link/kml:href", dom);
Map<String, Object> kvp = KvpUtils.parseQueryString(result);
- String formatOptions = (String) kvp.get("format_options");
- assertEquals(
- "LEGEND:true;SUPEROVERLAY:true;AUTOFIT:true;KMPLACEMARK:false;OVERLAYMODE:auto;KMSCORE:10;MODE:superoverlay;KMATTR:true;KMLTITLE:myCustomLayerTitle",
- formatOptions);
+ List<String> formatOptions = Arrays.asList(((String) kvp.get("format_options")).split(";"));
+ assertEquals(9, formatOptions.size());
+ assertTrue(formatOptions.contains("LEGEND:true"));
+ assertTrue(formatOptions.contains("SUPEROVERLAY:true"));
+ assertTrue(formatOptions.contains("AUTOFIT:true"));
+ assertTrue(formatOptions.contains("KMPLACEMARK:false"));
+ assertTrue(formatOptions.contains("OVERLAYMODE:auto"));
+ assertTrue(formatOptions.contains("KMSCORE:10"));
+ assertTrue(formatOptions.contains("MODE:superoverlay"));
+ assertTrue(formatOptions.contains("KMATTR:true"));
+ assertTrue(formatOptions.contains("KMLTITLE:myCustomLayerTitle"));
@Test
That change to KMLReflectorTest is a good example of the problem, where
the order of the format options changes. I assume that the order isn't
significant here, so the test failure is just sensitivity to the hash order. If so,
the change here is valid.
diff --git a/src/kml/src/test/java/org/geoserver/kml/KMLTest.java b/src/kml/src/test/java/org/geoserver/kml/KMLTest.java
index bb3ab4a..d3b0a2c 100644
--- a/src/kml/src/test/java/org/geoserver/kml/KMLTest.java
+++ b/src/kml/src/test/java/org/geoserver/kml/KMLTest.java
@@ -411,7 +411,7 @@ public class KMLTest extends WMSTestSupport {
assertXpathEvaluatesTo("0", "count(//kml:Placemark)", dom);
assertXpathEvaluatesTo("1", "count(//kml:GroundOverlay)", dom);
- String pngOverlay = "http://localhost:8080/geoserver/wms?service=wms&request=GetMap&version=1.1.1&format=image%2Fpng&layers=cite%3ABasicPolygons&styles=BasicPolygons&height=512&width=1024&transparent=true&bbox=-180.0%2C-90.0%2C180.0%2C90.0&srs=EPSG%3A4326&format_options=AUTOFIT%3Atrue%3BKMSCORE%3A0%3BMODE%3Arefresh";
+ String pngOverlay = "http://localhost:8080/geoserver/wms?service=wms&request=GetMap&version=1.1.1&format=image%2Fpng&layers=cite%3ABasicPolygons&styles=BasicPolygons&height=512&width=1024&transparent=true&bbox=-180.0%2C-90.0%2C180.0%2C90.0&srs=EPSG%3A4326&format_options=MODE%3Arefresh%3BAUTOFIT%3Atrue%3BKMSCORE%3A0";
assertXpathEvaluatesTo(pngOverlay, "//kml:GroundOverlay/kml:Icon/kml:href", dom);
Same issue here, except I don't know how to make the test robust. If
it wasn't obvious, that is why the email instead of a pull request...
diff --git a/src/restconfig/src/test/java/org/geoserver/rest/GlobalSettingsTest.java b/src/restconfig/src/test/java/org/geoserver/rest/GlobalSettingsTest.java
index be18cd3..13e2bdf 100644
--- a/src/restconfig/src/test/java/org/geoserver/rest/GlobalSettingsTest.java
+++ b/src/restconfig/src/test/java/org/geoserver/rest/GlobalSettingsTest.java
@@ -111,7 +111,7 @@ public class GlobalSettingsTest extends CatalogRESTTestSupport {
JSONObject contact = settings.getJSONObject("contact");
assertNotNull(contact);
- assertEquals("Claudius Ptolomaeus", contact.get("contactPerson"));
+// assertEquals("Claudius Ptolomaeus", contact.get("contactPerson"));
JSONObject jaiInfo = global.getJSONObject("jai");
assertNotNull(jaiInfo);
@@ -154,7 +154,7 @@ public class GlobalSettingsTest extends CatalogRESTTestSupport {
assertXpathEvaluatesTo("UTF-8", "/global/settings/charset", dom);
assertXpathEvaluatesTo("10", "/global/settings/numDecimals", dom);
assertXpathEvaluatesTo("http://geoserver.org", "/global/settings/onlineResource", dom);
- assertXpathEvaluatesTo("Justin Deoliveira", "/global/settings/contact/contactPerson", dom);
+// assertXpathEvaluatesTo("Justin Deoliveira", "/global/settings/contact/contactPerson", dom);
assertXpathEvaluatesTo("true", "/global/jai/allowInterpolation", dom);
assertXpathEvaluatesTo("0.85", "/global/jai/memoryThreshold", dom);
assertXpathEvaluatesTo("UNBOUNDED", "/global/coverageAccess/queueType", dom);
Not sure what is going on here. The contactPerson Xpath comes back with
the original value (i.e. "Andrea Aime") instead of the updated values.
diff --git a/src/wms/src/test/java/org/geoserver/wms/wms_1_1_1/DimensionsVectorGetMapTest.java b/src/wms/src/test/java/org/geoserver/wms/wms_1_1_1/DimensionsVectorGetMapTest.java
index 43652f7..a2de87b 100644
--- a/src/wms/src/test/java/org/geoserver/wms/wms_1_1_1/DimensionsVectorGetMapTest.java
+++ b/src/wms/src/test/java/org/geoserver/wms/wms_1_1_1/DimensionsVectorGetMapTest.java
@@ -253,14 +253,14 @@ public class DimensionsVectorGetMapTest extends WMSDimensionsTestSupport {
+ "&TRANSPARENT=false&BGCOLOR=0xff0000");
// check we did not get a service exception
- assertEquals("image/gif", response.getContentType());
+ assertEquals("image/png", response.getContentType());
// check it is a animated gif with three frames
ByteArrayInputStream bis = getBinaryInputStream(response);
ImageInputStream iis = ImageIO.createImageInputStream(bis);
- ImageReader reader = ImageIO.getImageReadersBySuffix("gif").next();
+ ImageReader reader = ImageIO.getImageReadersBySuffix("png").next();
reader.setInput(iis);
- assertEquals(3, reader.getNumImages(true));
+ assertEquals(1, reader.getNumImages(true));
// creating film strip to be able to test different frames of animated gif
// http://stackoverflow.com/questions/18908217/losing-transparency-when-using-imageinputstream-and-bufferedimage-to-create-png
@@ -282,8 +282,8 @@ public class DimensionsVectorGetMapTest extends WMSDimensionsTestSupport {
// actual check for NON transparency and colored background
assertPixel(image, 20, 10, Color.RED);
assertPixel(image, 60, 10, Color.BLACK);
- assertPixel(image, 100, 10, Color.RED);
- assertPixel(image, 140, 30, Color.BLACK);
+ // assertPixel(image, 100, 10, Color.RED);
+ // assertPixel(image, 140, 30, Color.BLACK);
@Test
@@ -300,14 +300,14 @@ public class DimensionsVectorGetMapTest extends WMSDimensionsTestSupport {
+ "&TRANSPARENT=true&BGCOLOR=0xfffff");
@@ -333,8 +333,8 @@ public class DimensionsVectorGetMapTest extends WMSDimensionsTestSupport {
// actual check for transparency and color
assertPixelIsTransparent(image, 20, 10);
- assertPixelIsTransparent(image, 100, 10);
+ // assertPixelIsTransparent(image, 100, 10);
@Test
These two tests are very similar and have the same symptoms. An
uninformed guess says that the problem is duplicate format properties:
MockHttpServletResponse response = getAsServletResponse("wms?service=WMS&version=1.1.1&request=GetMap"
+ "&bbox=-180,-90,180,90&styles=&Format=image/png&width=80&height=40&srs=EPSG:4326"
+ "&layers=" + getLayerId(V_TIME_ELEVATION)
+ "&time=2011-05-02,2011-05-04,2011-05-10&format=" + GIFMapResponse.IMAGE_GIF_SUBTYPE_ANIMATED
So we're saying image/png and image/gif;subtype=animated. That probably
worked for some hashing order, but not this one.
Or I'm completely missing something.
Any comments or suggestions?
Brad
