[Geoserver-devel] building with maven 2.1.0
So the source of the problems of not being able to build with maven 2.1.0 stems from the jalopy setup in the root pom.xml:
  <plugin>
     <groupId>org.codehaus.mojo</groupId>
     <artifactId>jalopy-maven-plugin</artifactId>
     <version>1.0-SNAPSHOT</version>
     <configuration>
      <convention>geoserver/geoserverjalopy.xml</convention>
      <failOnError>false</failOnError>
     </configuration>
     <dependencies>
      <dependency>
       <groupId>org.geoserver.maven</groupId>
       <artifactId>build-configs</artifactId>
       <version>1.7.5-SNAPSHOT</version>
      </dependency>
     </dependencies>
which depends on the build-configs module. But the build-configs module inheirets from this pom == kaboom, cyclic dependency.
So two options to fix:
1) Kill the jalopy configuration and the build-configs module since neither is used
2) Ensure that build-configs does not inheiret from the root pom by removing its parent. To do this we would probably have to duplicate some of the configuration from the current parent poms.
I vote for 1 :slight_smile:
Justin Deoliveira
OpenGeo - http://opengeo.org
Jalopy reformat is a failed experiment.
I vote for 1 as well.
Andrea Aime
+1 on option 1). Get rid of dead code, dead configuration, anything dead!
Justin Deoliveira wrote:
  <plugin>
     <configuration>
     </configuration>
     <dependencies>
      <dependency>
      </dependency>
     </dependencies>
Gabriel Roldan
+1
Jody
Andrea Aime
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-devel mailing list
