[Geoserver-devel] builds fixed, excepting geofence
With the nexus patch the other week the build server success rate has improved greatly. I turned off the “repair” jobs last week and have no additional reports of build failures.
If this is really in the clear we can start to turn on the parallel builds for each branch again.
The one blip is geofence where all the jobs are failing, and jenkins does not list any successful builds for these jobs. Checking the geofence-master job, it has a failure on a missing ‘geodb’ jar:
[ERROR] Failed to execute goal on project geofence-persistence: Could not resolve dependencies for project org.geoserver.geofence:geofence-persistence:jar:3.5-SNAPSHOT: Failed to collect dependencies at org.hibernatespatial:hibernate-spatial-h2-geodb:jar:1.1.3.1 → org.opengeo:geodb:jar:0.9: Failed to read artifact descriptor for org.opengeo:geodb:jar:0.9: Could not transfer artifact org.opengeo:geodb:pom:0.9 from/to spring-release (http://maven.springframework.org/release): Authorization failed for http://maven.springframework.org/release/org/opengeo/geodb/0.9/geodb-0.9.pom 403 Forbidden → [Help 1]
Searching the repo this dependency is available: https://repo.osgeo.org/#browse/search=keyword%3Dgeodb
Digging into this the pom.xml has not been migrated from repo.boundlessgeo.com.
Jody Garnett
Okay, beyond that the next failure is:
Transfer failed for http://repo1.maven.org/maven2/org/geotools/gt-api/21-SNAPSHOT/gt-api-21-SNAPSHOT.pom 501 HTTPS Required → [Help 1]
The 21-SNAPSHOTS are indeed no longer published anywhere, and the gt-api module was refactored away. Geofence will need to update …
Jody Garnett
      Transfer failed for
    501 HTTPS Required -> [Help 1]
The 21-SNAPSHOTS are indeed no longer published anywhere, and the gt-api module was refactored away. Geofence will need to update ...
There's a 2-fold problem here (1. only https allowed, 2. no 21-SNAPSHOT anywhere)
I've updated most of these problems in PR:
https://github.com/geoserver/geofence/pull/153
which bumps commons-beanutils to the same version that is used in GeoTools
last thing I was running into was resolving
org.geoserver.geofence:geofence-gui-resources:jar:3.5-SNAPSHOT
in "geofence-gui-resources", not sure where that is to be found. Details:
[ERROR] Failed to execute goal on project geofence-gui-resources: Could not resolve dependencies for project org.geoserver.geofence:geofence-gui-resources:jar:3.5-SNAPSHOT: The following artifacts could not be resolved: it.geosolutions.geogwt.core:geogwt-resources:jar:0.4-SNAPSHOT, it.geosolutions.geogwt.widgets.map:maptoolbar:jar:0.4-SNAPSHOT, com.extjs:gxt:jar:2.2.5-gwt22: Could not find artifact it.geosolutions.geogwt.core:geogwt-resources:jar:0.4-SNAPSHOT in osgeo-snapshots (https://repo.osgeo.org/repository/snapshot/) -> [Help 1]
[ERROR]
perhaps one of the experts can join in.
Frankly (and without meaning any insult) the maven structure of the geofence project has quite a bit technical dept.
I'm willing to have a crack at cleaning up the Maven things once we have a stable build
Mark
