Hi
I had some problems building todays trunk:
- maven was unable to find:
- jai_core
- jai_codec
- jai_imageio
- h2database
I downloaded them and installed them manually (as suggested).
- in “ModificationProxy.java” on line 236 I had to insert a cast:
before: List proxyInterfaces = Arrays.asList(…);
after: List proxyInterfaces = (List) Arrays.asList(…);
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Ziegler Stefan wrote:
Hi
1) maven was unable to find:
- jai_core
- jai_codec
- jai_imageio
- h2database
Looks like our opengeo repository is not serving these files... I will upload them. Thanks for the heads up.
2) in "ModificationProxy.java" on line 236 I had to insert a cast:
before: List<Class> proxyInterfaces = Arrays.asList(....);
after: List<Class> proxyInterfaces = (List) Arrays.asList(....);
Yeah, more or less a known issue with java 6. Thanks for the fix. Will commit it.
regards
Stefan
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Rötistrasse 4
4501 Solothurn
http://www.so.ch
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
