I will have a look at the layergroup behaviour for the interpolations parameter (not sure, I didn’t test this scenario explicitly). I guess we have “special” behaviour for the styles parameter to make layers and styles list align, so I will see if we are consistent with that behaviour on the new parameter too, and yes, the layer groups list should be expanded to a list of layers by the parser.
2015-05-14 8:15 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com8…>:
On Thu, May 14, 2015 at 1:19 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
When a layer group is used these two lists no longer line up (as the number of mapContent.layers is greater than the number of interpolations provided).
Hum… layer groups are expanded into the list of layers at the kvp parser, do not remember if we require these params to be already
expanded in the request, or if the kvp parser attempts an expansion of its own.
As said many times, “layer groups do not exist” inside GeoServer, they are aliases wiped out before we start processing requests
(inside the request parsers).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
