2015-05-13 0:38 GMT+02:00 Jody Garnett <jody.garnett@anonymised.com>:
Just wanted to double back to this issue, as GEOT-5064 indicates you want to back port the functionality - do you want to do that before next week’s release?
A number of GeoServer issues are stacking up on this subject (GEOS-7005, GEOS-6614).
Jody Garnett
On 1 April 2015 at 06:04, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
And here is the GeoServer one: https://github.com/geoserver/geoserver/pull/998
Thank you.
Mauro
2015-04-01 12:14 GMT+02:00 Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com>:
the pull request for the GeoTools part is here: https://github.com/geotools/geotools/pull/802
Mauro
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
2015-03-31 17:51 GMT+02:00 Jody Garnett <jody.garnett@anonymised.com>:
You can create a new Jira at http://osgeo-org.atlassian.net - placeholders have been created for the old Jira and the contents should be migrated across shortly. Attend the Skype meeting today to coordinate.
@mauro_bart
Jody Garnett
On 31 March 2015 at 08:38, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
so I did some work on this and it seems to be finally working (I had to fix a couple of bugs in the run, to take care of both direct and “classic” rendering path).
As prospected the change is partly in GeoTools, in particular in StreamingRenderer to add support for the “by layer” interpolation hint.
For the GeoServer work, unfortunately I didn’t managed to reuse the WCS interpolation kvp parser, for a couple of reasons:
- we want to support comma delimited values to allow for multiple layers having different interpolation (the WCS parser supports only one value)
- the wcs parser is tied to EMF classes for WCS
I would like to start preparing pull requests for this part, but I am not sure how to proceed due to “missing JIRA”. I would like to refer the JIRA number from the PR, as usual.
Is it possible to coordinate for “booking” JIRA numbers that I will create as soon as possible on the new JIRA?
It seems the first availables are GEOT-5064 and GEOS-6965. Can I use them for this work?
Thanks
Mauro
2015-03-27 15:51 GMT+01:00 Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com>:
Mauro
@mauro_bart
2015-03-27 14:12 GMT+01:00 Andrea Aime <andrea.aime@anonymised.com>:
I had a quick look, and for sure StreamingRenderer needs to be touched.
There is a generic getRenderingInterpolation() method that RenderCoverageReaderRequest call to get the current hint. We should probably make the interpolation value a property of the reader, so that we can set it when we create the reader, removing delegation to the outer class method.
GridCoverageRenderer already accepts an Interpolation object, so probably we just need to set it appropriately in RenderCoverageReaderRequest.
I also think that the hint only affects raster layers. From this first investigation it doesn’t seem too difficult, so probably is a good idea to make the parameter “multivalued”.
On Fri, Mar 27, 2015 at 9:15 AM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Hi Jody,
Indeed, that is why we have only the setting at the entire server level, because the streaming renderer cannot do interpolation per layer… not a massive change, but not entirely trivial I warn you, you’ll have to modify both streaming renderer and grid coverage renderer, as well as, I suppose, RasterLayer/GridCoverageLayer/GridReaderLayer to hold the interpolation value (don’t the the interpolation setting does anything for vector layers… might be wrong though).
2015-03-26 20:22 GMT+01:00 Jody Garnett <jody.garnett@anonymised.com>:
Wouldn’t it be more appropriate to do this on a layer by layer basis? Or are you focused on the final map production …
If you mean that the interpolation parameter should be a comma delimited list with one value for each layer (similar to style), this would make the change a bit more complex, because currently interpolation is achieved through rendering hints that are passed to StreamingRenderer for the whole rendering. If we want to make it layers specific we would need to move the logic inside StreamingRenderer, while now it’s in RenderedImageMapOutputFormat. It’s not impossible, I could investigate on the effort if people prefer to make it work this way.
@mauro_bart
