The issue is here
https://jira.codehaus.org/browse/GEOS-5921#comment-329355
The patch is here
https://github.com/mcrmcr/geoserver-1/commit/7c3e9aaf7aa4a625099fcd6bd88199b5ed1c15e7
The patch contains only a few lines, but it is a hack. As a consequence, a review would be nice.
@Justin, I think this class was invented by you.
Thanks to reviewer
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
I look at your code and are a little bit concerned about the solution for Login-page itself.
Wouldn’t it be easy to include “org.geoserver.web.GeoServerLoginPage” as a part of the queryString in any url?
In that way this hack would be a fairly decent security hole.
Roar Brænden
2013/7/23 Christian Mueller <christian.mueller@anonymised.com>
The issue is here
The patch is here
Thanks to reviewer
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Yep, this is an argument. The URL path is
http://localhost:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.GeoServerLoginPage&error=false
Some improvments:
Changing the ant pattern to “/web/” instead of “/web/**”
Check that the number of parameters is 2
Check that wicket:bookmarkablePage exists and has the value :org.geoserver.web.GeoServerLoginPage
Check that error parameter exists and has the value false or true.
I will check this and update the patch.
Christian
2013/7/24 Roar Brænden <roar.brenden.no@anonymised.com>
Roar Brænden
The issue is here
The patch is here
Thanks to reviewer
Done, please review at
https://github.com/mcrmcr/geoserver-1/commit/7306ceaf1a9fc98ba4c8b00d733ee7bf9bfce0aa
2013/7/24 Christian Mueller <christian.mueller@anonymised.com>
Some improvments:
Christian
Roar Brænden
The issue is here
The patch is here
Thanks to reviewer
I think this solution would be enough to close the security hole.
Some improvments:
Christian
Roar Brænden
The issue is here
The patch is here
Thanks to reviewer
