[Geoserver-devel] Call for vote GSIP-91
The GSIP is here
http://geoserver.org/display/GEOS/GSIP+91±+Enhance+authentication+filter+chain+configuration
This is the last round concerning authentication filter chains and I want to bring it in during the open development phase for 2.3.x. (This week)
Thanks
Christian
On Mon, Jan 14, 2013 at 10:30 AM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
The GSIP is here
I located the portion of the GUI where the filter chains are managed, but I cannot related that to the
contents of the proposal, nor I can find where the filter chains presented by the GUI
are configured. So… I have no idea?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Exactly this is the problem. On the top of the page you can manage individual authentication filters. (add,remove,edit). I want to have the same logic/look and feel for authentication chains. Until now, we have a fixed set of chains and I want to add flexibility. This is the hard part.
The additional SSL filter and including the HTTP method into the chain matching is the easy job.
Christian
2013/1/15 Andrea Aime <andrea.aime@anonymised.com>
The GSIP is here
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Jan 15, 2013 at 5:03 PM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
Ah I see. Yep, allowing the configuration of the filter chains seems indeed useful.
However, the GSIP is talking about some sort of pattern language, is that going to be exposed
in the GUI directly or is it just an example:
/rest/** (GET,POST)
/rest/** , SSL required
Ing. Andrea Aime
@geowolf
Technical Lead
Hey Christian,
How does this relate to GSIP-82?
Also, is there a patch i can check out?
-Justin
On Tue, Jan 15, 2013 at 11:16 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
/rest/** (GET,POST)
Ing. Andrea Aime
@geowolf
Technical Lead
Master SQL Server Development, Administration, T-SQL, SSAS, SSIS, SSRS
and more. Get SQL Server skills now (including 2012) with LearnDevNow -
200+ hours of step-by-step video tutorials by Microsoft MVPs and experts.
SALE $99.99 this month only - learn more at:
http://p.sf.net/sfu/learnmore_122512
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
@Andrea: No, there is no new pattern language, this is only an example. The admin has to deal with simple ANT patterns.
@Justin
GSIP 91 could be named “GSIP 82, part II”. It is the successor for completing chain configuration logic. This will be the last major rework in the security core code. I want to bring it in before Andrea is doing 2.3-beta1. I will push to finish this work until the weekend and create a patch.I hope you can spend some time on Monday for reviewing.
Christian
2013/1/15 Justin Deoliveira <jdeolive@anonymised.com>
On Tue, Jan 15, 2013 at 5:03 PM, Christian Mueller <mcrmcr21@anonymised.com…> wrote:
/rest/** (GET,POST)
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
On Wed, Jan 16, 2013 at 6:51 AM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
Ok, works for me, +1 (pending review of the patch
@Justin
Ah, this poses a problem.
The release procedure takes the last revision that passed the cite tests, and the relase is scheduled for Monday,
which means it will take a revision from a nightly build done in the night between Sunday and Monday,
too late for a patch review.
Moreover, using the last day implies that there won’t be any feedback requiring changes to the patch.
You can talk with Jody, that is going to do the beta release, but it would be much better if you
had the patch ready for Friday, assuming that Justin has time to have a look at it
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks for the hint, in this situation I will try to finish the core code until Friday and hope for a review from Justin. Fortunately, Justin is 8 hours behind me :slight_smile:
I think the admin GUI is not so critical and I try to finish until Sunday.
Christian
2013/1/16 Andrea Aime <andrea.aime@anonymised.com>
@Justin
Ing. Andrea Aime
@geowolf
Technical Lead
+0 on the proposal from me :slight_smile:
I have my monday slightly earlier than you, and need to complete the release promptly (or try again the next weekend).
Jody Garnett
Christian
On Wed, Jan 16, 2013 at 6:51 AM, Christian Mueller <mcrmcr21@anonymised.com…> wrote:
@Justin
Ing. Andrea Aime
@geowolf
Technical Lead
Sounds good Christian. I will try to review as soon as the patch is available.
On Tue, Jan 15, 2013 at 10:51 PM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
@Justin
Christian
2013/1/15 Justin Deoliveira <jdeolive@anonymised.com…>
Hey Christian,
-Justin
Justin Deoliveira
/rest/** (GET,POST)
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
Hi Justin, the core code is available for review.
https://github.com/mcrmcr/geoserver-1/commit/3a648f8465f33a8c924d2c9ec00f0e3bec5c938a
Tests are passing. The important classes are
GeoServerSSLFilter
GeoServerRequestMatcher
I will start working on the admin GUI now.
2013/1/16 Justin Deoliveira <jdeolive@anonymised.com>
On Tue, Jan 15, 2013 at 10:51 PM, Christian Mueller <mcrmcr21@anonymised.com…> wrote:
@Justin
Christian
Hey Christian,
-Justin
Justin Deoliveira
/rest/** (GET,POST)
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
0
Simone Giannecchini
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Wed, Jan 16, 2013 at 2:47 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Christian
@Justin
GSIP 91 could be named "GSIP 82, part II". It is the successor for
Moreover, using the last day implies that there won't be any feedback
at it
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Master Java SE, Java EE, Eclipse, Spring, Hibernate, JavaScript, jQuery
and much more. Keep your Java skills current with LearnJavaNow -
200+ hours of step-by-step video tutorials by Java experts.
SALE $49.99 this month only -- learn more at:
http://p.sf.net/sfu/learnmore_122612
Hey Christian,
Looked over this commit and it looks good. No issues here.
-Justin
On Thu, Jan 17, 2013 at 5:43 AM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
GeoServerSSLFilter
Justin Deoliveira
@Justin
Christian
Hey Christian,
-Justin
Justin Deoliveira
/rest/** (GET,POST)
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
+0
On the face of it, I am all for improvements and better control on
security but I dont think I have engaged enough with the recent
enhancements to judge this one.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
+1 here.
Having al SSL filter on the chain seems to be a very good improvement, especially on REST responses which send clear text and is possible in some cases to have back the store passwords in clear.
Had a quick look at the code, the headers look fine, javadoc on methods fine and there are test cases.
It would be possible to have also a doc update on filters configuration? If still there ignore this question, I did not checked.
Alessio.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
mob: +39 331 6233686
On Tue, Jan 22, 2013 at 8:57 PM, Phil Scadden <p.scadden@anonymised.com> wrote:
+0
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only – learn more at:
http://p.sf.net/sfu/learnnow-d2d
The whole security doc needs some love, this is on my TODO list
Christian
2013/1/23 Alessio Fabiani <alessio.fabiani@anonymised.com>
+1 here.
Alessio.
@alfa7691
+0
