I was trying to generate the usual “highway” style with css, with proper line joins, but I don’t see how one can generate a SLD with multiple feature type styles.
CSS has a z-index property, so I’ve tried with the following, but it does not work:
stroke: black, white;
stroke-width: 8, 4;
stroke-linecap: round;
stroke-linejoin: round;
:nth-stroke(1) {
z-index: 1;
the result is still:
I see the code has support for a stroke-z-index and a z-index property (btw, both undocumented), but they seem to have no effect, the generated SLD still has a single feature type style.
What am I missing?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The :stroke and :nth-stroke(n) selectors are specifically for properties applied to well-known marks. Your :nth-stroke rule doesn’t apply because (a) z-index does not apply for a well-known mark and (b) you don’t use any well-known marks anyway.
Instead, you should use the z-index property the same way you’ve used the others:
stroke-width: 8, 4;
z-index: 0, 1;
(attachments)
On Tue, Jul 23, 2013 at 9:07 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
stroke-width: 8, 4;
:nth-stroke(1) {
z-index: 1;
What am I missing?
Ing. Andrea Aime
@geowolf
Technical Lead
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
On Tue, Jul 23, 2013 at 3:14 PM, David Winslow <dwinslow@anonymised.com> wrote:
applied to well-known marks. Your :nth-stroke rule doesn't apply because
(a) z-index does not apply for a well-known mark and (b) you don't use any
Instead, you should use the z-index property the same way you've used the
others:
stroke-width: 8, 4;
z-index: 0, 1;
Ah nice, will make sure to document this. Thanks!
Ing. Andrea Aime
@geowolf
Technical Lead
