Can you please say me what could be the solution for this error
Access denied: java.lang.RuntimeException org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:97) at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:327) at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:25) at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:782) at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:424) at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:774) at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:249) at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1242) at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:717) at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:494) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95) at org.eclipse.jetty.server.Server.doStart(Server.java:282) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at net.sourceforge.eclipsejetty.starter.embedded.JettyEmbeddedAdapter.start(JettyEmbeddedAdapter.java:67) at net.sourceforge.eclipsejetty.starter.common.AbstractJettyLauncherMain.launch(AbstractJettyLauncherMain.java:85) at net.sourceforge.eclipsejetty.starter.embedded.JettyEmbeddedLauncherMain.main(JettyEmbeddedLauncherMain.java:42) Caused by:
and when i run geoserver internally through eclipse, it doesnt work…!!!
my hello-wps program also fails to execute even after registering under SpringBeans.
I would be very greateful with the response
GIRIJA KALYANI
GFM DEPARTMENT
IIRS-ITC
ISRO
