today trying to build the extensions with -Prelease I
stumbled upon this:
[INFO] Building ArcSDE DataStore Extension
[INFO] [clean:clean]
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
Downloading: http://maven.geotools.fr/repository//com.esri/poms/jsde_sdk-9.2.pom
Downloading: http://lists.refractions.net/m2//com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://www.mortbay.org/maven2/release/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://maven.restlet.org/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://repo1.maven.org/maven2/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://maven.geotools.fr/repository//com.esri/poms/jsde_jpe_sdk-9.2.pom
Downloading: http://lists.refractions.net/m2//com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://www.mortbay.org/maven2/release/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://maven.restlet.org/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://repo1.maven.org/maven2/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://maven.geotools.fr/repository//com.esri/jars/jsde_sdk-9.2.jar
Downloading: http://lists.refractions.net/m2//com/esri/jsde_sdk/9.2/jsde_sdk-9.2.jar
Downloading: http://www.mortbay.org/maven2/release/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.jar
Downloading: http://maven.restlet.org/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.jar
Downloading: http://repo1.maven.org/maven2/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.jar
Downloading: http://maven.geotools.fr/repository//com.esri/jars/jsde_jpe_sdk-9.2.jar
Downloading: http://lists.refractions.net/m2//com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.jar
Downloading: http://www.mortbay.org/maven2/release/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.jar
Downloading: http://maven.restlet.org/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.jar
Downloading: http://repo1.maven.org/maven2/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) com.esri:jsde_sdk:jar:9.2
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=com.esri -DartifactId=jsde_sdk -Dversion=9.2 -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=com.esri -DartifactId=jsde_sdk -Dversion=9.2 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver.extension:arcsde:jar:1.7.2-SNAPSHOT
2) com.esri:jsde_sdk:jar:9.2
2) com.esri:jsde_jpe_sdk:jar:9.2
mvn install:install-file -DgroupId=com.esri -DartifactId=jsde_jpe_sdk -Dversion=9.2 -Dpackaging=jar -Dfile=/path/to/file
mvn deploy:deploy-file -DgroupId=com.esri -DartifactId=jsde_jpe_sdk -Dversion=9.2 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
2 required artifacts are missing.
for artifact:
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
refractions (http://lists.refractions.net/m2/),
geotools (http://maven.geotools.fr/repository/),
mortbay (http://www.mortbay.org/maven2/release)
[INFO] Total time: 18 seconds
[INFO] Finished at: Sun Jan 18 18:54:43 CET 2009
[INFO] Final Memory: 18M/32M
Oh hum, those look like the modules one must get from the SDE install,
and that we cannot redistribute so... I guess there is a problem with
the extension dependencies?
Andrea Aime
OpenGeo - http://opengeo.org
Andrea Aime ha scritto:
stumbled upon this...
The same happens with the sqlserver module, I've got
this failed dependency:
com.microsoft:sqljdbc:jar:1.2
I was also wondering about these modules... since they
don't contain any code, shouldn't the packaging
be just "pom" instead of "jar"?
Anyways, the reason for me trying them was to check I
did the right things when moving the ogr module into
extensions while adding it to the release.
I tried to be careful, but keep an eye,
as I have no real way to double check.
Andrea Aime
Yeah, the way I set it up was to add the dependencies on the jars that have to be downloaded manually. The rationale being that the two cases where one will want to engage the extension (1. actually using it, or 2. doing a release) will need the actual libraries.
We can set up the extensions not to include the libs but then we need to add another profile for them which makes things a bit more complicated. And we need to make sure those profiles are engaged when building a release.
Thoughts?
Justin Deoliveira
Thoughts?
Afaik the sde libraries we cannot redistribute, so they should
not be around when making a release, the user should add them
manually?
Moreover, the way it's set up, only one that has all those extra
packages can make a release, which does not make much sense (have
I to buy a SDE license or to download the full SQL Server
to make a release?)
Btw, the sql server one, can we redistribute? If so, it should be added to the maven repos no?
I mean, look at what happened to me, I could not even test if the
extension I was trying to add was good for the release, or not...
In fact in gt2 we have an extra profile in the oracle pom that disables
the dummy jars and enables the real ones. It seems the only practical
way to go. Generally speaking, I'm open to any process that can be
described in a wiki page, applied by everyone, without buying software
or making big (or platform dependent) downloads works for me.
Andrea Aime
FYI,
The extensions and what we actual redistribute are separate. But yeah, i guess the only option here are to add some profiles to the extensions. I will put this on the list of things todo.
-Justin
Thoughts?
manually?
to make a release?)
Justin Deoliveira
