[Geoserver-devel] Cannot view logs when using JDBCStore
Hello,
I was testing JDBCStore on GeoServer 2.9.1 (CentOS 6.6, Tomcat8, PostgreSQL), and I have ran into a problem - once I have JDBCStore set up, I can not see the logs past the point where JDBCStore was initialized.
The last to lines in the geoserver.log file in the old data dir are:
2016-09-12 22:05:19,315 INFO [geoserver.jdbcloader] - JDBCConfig using JDBC DataSource Optional.of(jdbc:postgresql://localhost:5432/gsdata)
2016-09-12 22:05:19,560 INFO [jdbcstore.internal] - Initializing Resource Store Database.
If I do a WMS request, then look at the GeoServer log from the geoserver UI, these are still the last to lines in the logs.
If I do “curl -v -u admin:geoserver -XGET http://localhost:8080/geoserver/rest/resource/logs/geoserver.log”, these are still the last to lines in the logs.
I can look at the JDBCStore database and see that there is an entry for geoserver.log, and that it contains about 285 KB of hexadecimal text.
Is there anything obvious I might be doing wrong here to get this result?
Torben
Update: The expected log messages are visible in /var/log/tomcat8/catalina.out (among the other tomcat log messages), so GeoServer is still doing logging, it just seems to be going to (or looking at) the wrong place.
Torben
On Mon, Sep 12, 2016 at 3:59 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hello,
Torben
HI Torben,
if I had to venture a guess, maybe it’s one bit too much migrated to the resource stuff? Log4j at the end of the day
can only log on the file system
On Tue, Sep 13, 2016 at 2:07 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Hello,
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Tue, Sep 13, 2016 at 1:05 AM, Andrea Aime <andrea.aime@anonymised.com>
wrote:
HI Torben,
if I had to venture a guess, maybe it's one bit too much migrated to the
That seems to make sense - Neils, you did most of the JDBCStore work, do
you have any insight into this behavior?
Torben
Hmm, strange. We always pass a file to the logger, irrespective of the used resource store. As Andrea said, there is no other way. But then I wonder what goes wrong after the store has been initialised. I'll have to debug.
Regards
Niels
On 14-09-16 18:36, Torben Barsballe wrote:
On Tue, Sep 13, 2016 at 1:05 AM, Andrea Aime <andrea.aime@anonymised.com <mailto:andrea.aime@anonymised.com>> wrote:
    HI Torben,
That seems to make sense - Neils, you did most of the JDBCStore work, do you have any insight into this behavior?
Torben
Torben,
Note that all of the logging goes to both the log file and the standard output. So the fact that you can find all the logs in catalina.out is perfectly normal.
The questions is only why it stops logging to the file. Looking into it.
Regards
Niels
Regards
Niels
    HI Torben,
Torben
Torben,
I have found the issue. The events are actually logged properly to the log file... but the problem is that afterwards the old log file is recached from the database!
The log-file should simply never be stored in the database. We have a system for that in place: we can configure ignored directories (like data, workspaces, jdbcstore, data...) which are not imported to begin with, and furthermore jdbcresourcestore forwards any request for them to the filesystembasedstore.
Unfortunately, we forgot to add the "logs" directory to the default config files. Also, I have found a bug that makes it possible to still read children of the ignored directories from the database. I have made a PR to resolve the issue: https://github.com/geoserver/geoserver/pull/1821
If this one is merged, and you make sure that logs is included in your jdbcstore config file, the problem will be resolved.
Regards
Niels
Regards
Niels
    HI Torben,
Torben
