Hi Jody,
I have found the login user/pass in the code. i can now login. But, i have found a problem with your wms server. When i send a request for the capabilities, for example:
http://metis/geoserver/wms?request=GetCapabilities&service=WMS
I get back the capabilities ok, but the xml is not valid. I have attached the capabilities xml file, for you to have a look. Were you aware that the xml you return does not validate against the dtd?
Try validating yourself. There are many errors.
Jamie
P.S. i would like to get involved, and help you guys out, but time has been a problem for me lately. Which IDE do you guys use?
----Original Message Follows----
To: Jamie Eyre <jweyre@anonymised.com>
CC: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] can't install geoserver.war
Date: Wed, 10 Mar 2004 01:09:48 -0800
Jamie Eyre wrote:
I have used your xml file you sent, but i still get the error in tomcat. I did notice that if i comment out the JSPCompiler servlet in the web.xml file, I no longer get that error, but then, of coarse, when i try to run the webapp, it cannot find the JSPCompiler servlet. Any ideas?
Sorry man it is really late for me, you can skip the JSPCompiler and go directly to geoserver/welcome.do
And the jsps will compile as you use them for the first time.
I am afraid we have been testing with Resin, perhaps the JSPCompiler does not work with tomcat.
_________________________________________________________________
MSN Premium with Virus Guard and Firewall* from McAfee® Security : 2 months FREE* http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
(attachments)
capabilities.xml (3.94 KB)
