[Geoserver-devel] Can't start geoserver-2.9-SNAPSHOT on Windows
Have anybody tried to start master snapshots on Windows? The bin-zip that I downloaded today yields
Error: Could not find or load main class
My jre version is jre1.8.0_72 (32-bit)
-Jukka Rahkonen-
Jukka,
do you mean this zip?:
http://ares.boundlessgeo.com/geoserver/master/geoserver-master-latest-bin.zip
I cannot answer for Windows but I just tested and it started for me on openjdk-8-jre:amd64 8u77-b03-1 on debian unstable.
- Are you starting it with bin\startup.bat?
- Is your working directory the top-level unzipped geoserver-2.9-SNAPSHOT directory?
- Are you able to manually run the jar with this?:
cd \wherever\you\put\2.9-SNAPSHOT
java -Xmx1024m -DGEOSERVER_DATA_DIR=\wherever\you\put\2.9-SNAPSHOT\data_dir -Djava.awt.headless=true -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar start.jar
- What is the output of this?:
java -version
Kind regards,
Ben.
On 31/03/16 01:07, Rahkonen Jukka (MML) wrote:
-Jukka Rahkonen-
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785471&iu=/4140
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
And please send us the full console output.
Kind regards,
Ben.
-Jukka Rahkonen-
Director
New Zealand
I can confirm this behaviour with today’s master. It will start when you run it from the command line but fails when you double click start.bat or run from the command line
The console says:
Welcome to GeoServer!
The GEOSERVER_HOME environment variable is not defined.
Temporarily setting GEOSERVER_HOME to the following directory:
C:\Users\astun\Desktop\geoserver-2.9-SNAPSHOT
The GEOSERVER_DATA_DIR environment variable is not defined correctly.
Temporarily setting GEOSERVER_DATA_DIR to the following directory:
C:\Users\astun\Desktop\geoserver-2.9-SNAPSHOT\data_dir
Please wait while loading GeoServer…
Press any key to continue . . .
for Java
java version “1.8.0_77”
Java™ SE Runtime Environment (build 1.8.0_77-b03)
Java HotSpot™ 64-Bit Server VM (build 25.77-b03, mixed mode)
Ian
Kind regards,
Ben.
-Jukka Rahkonen-
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Ian Turton
I have vague memories that this was already visible when we first switched to a newer Jetty but
got somehow fixed… wondering if the spring 4 upgrade (and associated servlet api upgrade)
is the cause of this failure?
The console says:
for Java
Ian
Kind regards,
Ben.
-Jukka Rahkonen-
Director
New Zealand
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
