This IS a valid java path for me
RUN_JAVA=C:\ProgramData\Oracle\Java\javapath\java.exe
So it seems that the only fix that is needed is to remove the empty JAVA_OPTS variable. I made some mess with copy-paste in the last mail so I’ll add the line that works for me here:
“%RUN_JAVA%” -DGEOSERVER_DATA_DIR=“%GEOSERVER_DATA_DIR%” -Djava.awt.headless=true -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar start.jar
-Jukka-
Lähettäjä: Rahkonen Jukka (MML) [mailto:jukka.rahkonen@…4189…]
Lähetetty: 30. maaliskuuta 2016 16:38
Vastaanottaja: Ian Turton; Ben Caradoc-Davies
Kopio: geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] Can’t start geoserver-2.9-SNAPSHOT on Windows
There are probably two issues which prevent the launch command to work:
“%RUN_JAVA%” “%RUN_JAVA%” “%JAVA_OPTS%” -DGEOSERVER_DATA_DIR=“%GEOSERVER_DATA_DIR%” -Djava.awt.headless=true -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar start.jar-DGEOSERVER_DATA_DIR=“%GEOSERVER_DATA_DIR%” -Djava.awt.headless=true -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar start.jar
The first one is that environment variable JAVA_OPTS is empty at this stage. Removing “%JAVA_OPTS%” makes Geoserver to start but there can be another issue with RUN_JAVA environment.
If there is a valid JAVA_HOME set on the computer before running startup.bat everything is probably going well. However, for me JAVA_HOME is empty before I start to run the startup.bat and when the batch goes so far as trying to start java it is set to this peculiar value:
So two places to look at:
Empty JAVA_OPTS is bad
This block in the batch file may set a surprising value for the RUN_JAVA
:trySystemJava
for /f %%i in (‘where java’) do set RUN_JAVA=%%i
rem — we might be on amd64 having only x86 jre installed —
if “%RUN_JAVA%”==“” if DEFINED ProgramFiles(x86) if NOT “%PROCESSOR_ARCHITECTURE%”==“x86” (
rem — restart the batch in x86 mode—
echo Warning: No java interpreter found in path.
echo Retry using Wow64 filesystem [32bit environment] redirection.
%SystemRoot%\SysWOW64\cmd.exe /c %0 %*
exit /b %ERRORLEVEL%
if “RUN_JAVA%”==“” goto noJava
goto checkGeoServerHome
-Jukka Rahkonen-
Lähettäjä: Ian Turton [mailto:ijturton@…403…]
Lähetetty: 30. maaliskuuta 2016 16:23
Vastaanottaja: Ben Caradoc-Davies
Kopio: Rahkonen Jukka (MML); geoserver-devel@lists.sourceforge.net
I can confirm this behaviour with today’s master. It will start when you run it from the command line but fails when you double click start.bat or run from the command line
The console says:
Welcome to GeoServer!
The GEOSERVER_HOME environment variable is not defined.
Temporarily setting GEOSERVER_HOME to the following directory:
C:\Users\astun\Desktop\geoserver-2.9-SNAPSHOT
The GEOSERVER_DATA_DIR environment variable is not defined correctly.
Temporarily setting GEOSERVER_DATA_DIR to the following directory:
C:\Users\astun\Desktop\geoserver-2.9-SNAPSHOT\data_dir
Please wait while loading GeoServer…
Error: Could not find or load main class
Press any key to continue . . .
for Java
java version “1.8.0_77”
Java™ SE Runtime Environment (build 1.8.0_77-b03)
Java HotSpot™ 64-Bit Server VM (build 25.77-b03, mixed mode)
Ian
On 30 March 2016 at 13:36, Ben Caradoc-Davies <ben@…4191…> wrote:
And please send us the full console output.
Kind regards,
Ben.On 31/03/16 01:07, Rahkonen Jukka (MML) wrote:
Have anybody tried to start master snapshots on Windows? The bin-zip that I downloaded today yields
Error: Could not find or load main classMy jre version is jre1.8.0_72 (32-bit)
-Jukka Rahkonen-
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785471&iu=/4140
Geoserver-devel mailing list
Ian Turton
