trying to start up GeoServer trunk today I get the following:
04 mag 16:56:01 ERROR [mortbay.log] - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL [file:/home/aaime/devel/git-gs/src/gwc/target/classes/applicationContext.xml]: Cannot resolve reference to bean ‘DiskQuotaStore’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘DiskQuotaStore’ defined in URL [file:/home/aaime/devel/git-gs/src/gwc/target/classes/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is com.google.common.cache.CacheLoader$InvalidCacheLoadException: CacheLoader returned null for key LayerInfoImpl-3c1d9af7:1366d483c57:-7ffb.:
at com.google.common.cache.LocalCache$Segment.getAndRecordStats(LocalCache.java:2383)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2351)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2313)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2228)
at com.google.common.cache.LocalCache.get(LocalCache.java:3965)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3969)
at com.google.common.cache.LocalCache$LocalManualCache.get(LocalCache.java:4829)
at org.geoserver.gwc.layer.CatalogConfiguration.getTileLayerById(CatalogConfiguration.java:267)
at org.geoserver.gwc.layer.CatalogConfiguration.getTileLayer(CatalogConfiguration.java:292)
at org.geoserver.gwc.layer.CatalogConfiguration.getTileLayer(CatalogConfiguration.java:1)
at org.geowebcache.layer.TileLayerDispatcher.getTileLayer(TileLayerDispatcher.java:97)
at org.geowebcache.diskquota.storage.TilePageCalculator.getTileSetsFor(TilePageCalculator.java:85)
at org.geowebcache.diskquota.storage.BDBQuotaStore.createLayer(BDBQuotaStore.java:257)
at org.geowebcache.diskquota.storage.BDBQuotaStore.access$700(BDBQuotaStore.java:40)
at org.geowebcache.diskquota.storage.BDBQuotaStore$StartUpInitializer.call(BDBQuotaStore.java:224)
at org.geowebcache.diskquota.storage.BDBQuotaStore$StartUpInitializer.call(BDBQuotaStore.java:186)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
I’ve let maven download the latest build of GWC and rebuilt everything, but it may be
the issue is some corruption inside the data dir.
As usual solved by getting rid of GWC dependencies but… does it ring any bell?
Even if it’s corruption of some kind (maybe I abruptly closed GeoServer without giving it a
chance for a clean closing) it should not prevent startup.
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
