[Geoserver-devel] CapabilitiesCacheHeadersCallback - caches getcap inappropriately (Time Series)
I noticed that the GetCap document was not up-to-date. When I dug into it, I found that CapabilitiesCacheHeadersCallback was returning a 304 (i.e. no changes).
However, this is a timeseries dataset (ie. Time Dimension tab on Layer Publish).
(i.e. a GeoGIG or PostGIS dataset with a time column)
The issue is that the dataset is changing. A new Time value is inserted into the dataset - the getcap (set to LIST) should show this new value. However, the document is cached because the catalog hasn’t detected any changes.
We talked about this earlier (“Time dimension on Vector Layer is SLOW”) and decided that caching this information is inappropriate (and I agree) for this reason.
What should be done about this?
Dave
Hi Dave,
the callback in question extends the official OGC conditional capabilties request (based on the
update sequence number) to non compliant clients that can do HTTP conditional requests instead.
So the answer would be, “if something changes, you’d have to increment the update sequence,
since your caps document changed”.
However, I understand and agree this is indeed a problem, the capabilities document can change
due to dimensions, but also due to security, without anything touching the GeoServer configuration (which
would bump the update sequence).
As a quick fix, there is already a CAPABILITIES_CACHE_CONTROL_ENABLED envvar/sysvar/servlet context variable
that can be set to false to disable the callback.
As a longer term fix, the callback should probably be modified to identify elements making the caps
dynamic. Like, for example, scan the layers available to the current user and create a digest out of them
(fixes security) and if during the scan any has dimensions, uh, probably disable the conditional request fully.
On the background, there is still the issue of proper OGC clients making update sequence based conditional
request, those will still fail to notice something has changed… this mapserver ticket has enough information
about it without you needing to read the OWS specifications:
https://trac.osgeo.org/mapserver/ticket/2384
Hum… from what I read, the “etag” computed above could also be used for conditional negotiation at the OGC
level.
On Fri, Mar 31, 2017 at 8:06 PM, Dave Blasby <dblasby@anonymised.com> wrote:
Dave
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi, Andrea,
I saw the “CAPABILITIES_CACHE_CONTROL_ENABLED” flag, and that’s what I’ve been using.
I agree with what you’re saying, I expect the etag (which is, I believe, the same token used in the conditional request) would need to be extended with non-directly-catalog related information (or have a “don’t cache” value). I think it is currently “-”. I will chat with Quinn.
Thanks for your response,
Dave
On Tue, Apr 4, 2017 at 2:45 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Dave,
level.
Dave
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Nice,
I’d still open a ticket for it.
On Tue, Apr 4, 2017 at 6:59 PM, Dave Blasby <dblasby@anonymised.com> wrote:
Hi, Andrea,
Dave
Hi Dave,
level.
Dave
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
