The illegal character in the response is a non-issue. The problem was
caused by the test harness developed by my team.
Sent: Friday, February 13, 2009 9:47 AM
To: 'Gabriel Roldan'; Jody Garnett
Cc: geoserver-devel@lists.sourceforge.net;
geotools-devel@lists.sourceforge.net
Subject: RE: [Geoserver-devel] cascading WFS
If the ArcGIS Server WFS is set up using ESRI's basic setup wizards it
appears that the service URL will consistently follow this pattern:
http://<hostname>/arcgis/services/<servicename>/MapServer/WFSServer
I think it could be different if the service uses an external
capabilities file or the administrator does something out of the
ordinary, but I don't really know.
From: Gabriel Roldan [mailto:groldan@anonymised.com]
Sent: Thursday, February 12, 2009 11:28 PM
To: Jody Garnett
Cc: Keane, Tim; geoserver-devel@lists.sourceforge.net;
Subject: Re: [Geoserver-devel] cascading WFS
On Friday 13 February 2009 01:15:29 Jody Garnett wrote:
Is there any way we can detect an ESRI server is being used (perhaps a
common pattern in the capabilities url; or some hint in the
capabilities
document?)
hum, it doesn't seem so. Ionic puts its own namespace declaration so its
easy. For others we're fallbacking to a comment in the getcaps like <!--
... CubeWerx ...-->, or worse, a pattern in the url, like "*MapServer*".
but these two doesn't seem like sharing any pattern. Another approach
could be to hit the server with a couple strategic queries and
heuristically find out what it supports... but given the 1.0 datastore
is unmaintained it doesn't seem like anyone is gonna put that much
effort into it. But I do am looking forward for the time to port 1.0 to
the design used for 1.1, but it lacks transactions yet.
Gabriel
Perhaps we can adjust our encoding of Filter as a special case
while we wait for a bug report. Good detective skills to figure out
what
they will accept.
Jody
On Fri, Feb 13, 2009 at 6:34 AM, Keane, Tim <tkeane@anonymised.com>
wrote:
> Gabriel-
> It claims to be WFS 1.1.0.
> I have also found that it fails to parse ogc elements if the
namespace is
> specified (ie: <Filter> parses, but <ogc:Filter> does not).
> It also appears that they are not properly escaping textual values
> returned from the db as you can see if you open the attached
response
> doc.
> I complained loudly to ESRI so we'll see what happens.
> -Tim
> *From:* Gabriel Roldan [mailto:groldan@anonymised.com]
> *Sent:* Thursday, February 12, 2009 2:17 PM
> *To:* Keane, Tim
> *Cc:* geoserver-devel@lists.sourceforge.net;
> *Subject:* Re: cascading WFS
> On Thursday 12 February 2009 15:32:22 Keane, Tim wrote:
> > Gabriel-
> > I have been working on producing the requests and responses as you
> > suggested. However, I am having a no luck getting ArcGIS Server's
WFS
> > to properly apply Filters to GetFeature requests. So for now I am
going
> > to back burner this.
> I understand. Still, not everything may be lost. Do the ArcGIS WFS
Server
> claim to be 1.1.0 or 1.0?
> In the event they don't support any filtering at all, we could still
make
> use of it and apply the filtering at run time, as we do with any non
> supported part of a filter. Yes, it will be much slower than
desirable,
> cause the server wouldn't be applying any filtering and hence
everytime
> we access it is like a full table scan, but would at least let fetch
the
> data.
> If that's acceptable we could go that way until figuring out if/what
> subset of the filter spec an ArcGIS WFS actually supports?
> Cheers,
> Gabriel
> > Thanks for your help.
> > -Tim
> > Sent: Thursday, February 05, 2009 10:12 AM
> > To: Keane, Tim
> > Subject: Re: cascading WFS
> > Hi Tim, cc'ing the list
> > confirmed we lack a binding in our parser for the
> > ows:extendedCapabilities
> > element.
> > What would be good in order to make sure we support ArcGIS server
is
> > for
> > you
> > to create a JIRA issue for it
(http://jira.codehaus.org/browse/GEOT),
> > assign
> > to the data-wfs module, me (groldan) as the responsible, and
attach the
> > following information:
> > - A GetCapabilities document just like the one you sent me
> > - The response of a couple DescribeFeatureType requests
> > - The response of a couple GetFeature requests.
> > for the GetFeature requests I would need the originating requests
and
> > its
> > responses. Ideally, there should be a couple of them with GET and
a
> > couple
> > with POST method. And, even more, I need to check the following:
> > - whether the server respects the maxFeatures param
> > - whether the server respects the resultType param
> > - whether the server works with attribute based filters, geometry
> > filters, and
> > mixed attribute/geometry filters
> > - whether the server respects the sortBy param
> > Despite what WFS servers declare in the capabilities, most of them
have
> > trouble with at least one of those parameters.
> > If I had that information as separate xml files, I could set them
up as
> > unit
> > test data suite for an ArcGIS strategy in the WFS DataStore the
same
> > way
> > I did
> > for the others, or if you feel like doing so you can go ahead with
the
> > code,
> > check out how the test data is set up for the others (you'll see
> > although the
> > 1.0 and 1.1 datastores lives in the same module, the 1.0 one is
almost
> > deprecated and waiting for me to have the energy to move it to the
new
> > framework created for the 1.1 one).
> > Best regards,
> > Gabriel
> > [quote]
> > > > >> ...I saw that you were the last
> > > > >> one to edit the page on WFS Datastores. I am having
problems
> > creating
> > > > >> a
> > > > >> datasore that connects to an ESRI ArcGIS Server WFS.
Geoserver
> > 1.7
> > > > >> chokes on the getCapabilities document attached with the
> > following:
> > > > >> Parsing failed for OperationsMetadata:
> > java.lang.RuntimeException:
> > > > >> Unable to set property: ExtendedCapabilities for eobject:
{http://www.opengis.net/ows\}_OperationsMetadata<http://www.openg
> > > > >>is.net/ows%7D_OperationsMetadata>
> > > > >> Is the WFS Datastore a viable option for federating WFS
requests
> > or
> > > > >> would I be better off taking a different approach. I was
hoping
> > that
> > > > >> you might give me some insight before I start digging into
the
> > > > >> geoserver
> > > > >> source to find out that this is not really a mature
datstore
> > option.
> > > > >> Thanks
> > > > >> -Tim
> > [quote]
> > Gabriel Roldan
> > OpenGeo - http://www.opengeo.org
> Gabriel Roldan
>----- Open Source Business Conference (OSBC), March 24-25, 2009, San
> Francisco, CA
> -OSBC tackles the biggest issue in open source: Open Sourcing the
> Enterprise
> -Strategies to boost innovation and cut costs with open source
> participation
> -Receive a $600 discount off the registration fee with the source
code:
> SFAD
> http://p.sf.net/sfu/XcvMzF8H
> Geoserver-devel mailing list
> Geoserver-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Gabriel Roldan
