I'm a bit in a bind for a number of issues related to resource
validation and resource names.
Say I'm adding again an existing dataset, without aliasing it,
and I press submit to add the "clone" [1]. What I get is, rightfully,
the following stack trace:
java.lang.IllegalArgumentException: Resource named 'mosaic' already exists in store: 'mosaic'
at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:349)
at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:328)
at org.geoserver.security.SecureCatalogImpl.add(SecureCatalogImpl.java:845)
at org.geoserver.web.data.ResourceConfigurationPage$4.onSubmit(ResourceConfigurationPage.java:115)
Ok. So I want to add a validation in the UI that prevents this.
Mumble... how to do this? The validation will trigger before the
resources are updated, so in the validator I have in my hands just
the old state of the ResourceInfo, and the new name.
I would like to call Catalog.validate(resource) to avoid duplicating
the validation logic, but to do so I'd need to clone the resource first
and force the new name onto it. Is there any facility to duplicate
a ResourceInfo (maybe I could just make a method that serializes and
un-serializes it, this would effectively deep clone it).
And even if I do, the validator will have to return a proper error
message... say tomorrow you add a new validation, how do I associate
the catalog validation exception with a meaningful message (eventually
translated?). It seems that if I want to have i18n error messages
I have to replicate the validation logic anyways?
While looking into CatalogImpl.validate(ResourceInfo) I also noticed
the name validation occurs only if the layer is new... which does
not look like a good idea, as people can change the name afterwards
as well, and make it collide with another layer. The code should
check if the catalog already contains a resource with the same name
in the same workspace, and pass only if none is found, or if the
resource found is different from the one at hand (which requires
some id based comparison, with an id different than the name)...
Sooo... suggestions?
[1]: for those that do not know, since 1.6.x it's possible to add the
same shapefile/table multiple times, and have it act as a different
layer, with different styles and parameters, provided each
"instance" is given a different "alias"
Andrea Aime
OpenGeo - http://opengeo.org
